Better Brake Pads I35
Old Oct 8, 2006 | 09:52 PM
osetleo's Avatar
Guys,
I am looking for a good set of brake pads for my I35. Would you please suggest from your experience. Should it be OEM or something aftermarket (how about Akebono Ceramics, for example)? I am not very aggressive driver and I am looking for low dust set that does the job.
Thank you
Old Oct 8, 2006 | 10:02 PM
n3985's Avatar
大陆弟弟
If you are just looking for some simple pads without imrpoved performance in mind, the Akebono will be good.
Old Oct 9, 2006 | 07:15 AM
MetaOrbit's Avatar
Got Projectors?
What he said ^
Old Oct 9, 2006 | 07:30 AM
NewLoveI30's Avatar
I have had a good experience with the Hawk HPS pads. Every once in a while I get a small amount of juddering, but it seems to come and go.
The brembo blank and HPS combo has gone much longer than stock without warping. Pretty good IMO.
Old Oct 10, 2006 | 01:27 PM
cprx7's Avatar
I am currently using Hawk HPS with brembo cross-drilled. They are good but I am not too impressed. Next brake job I do, I will go with Axxis Ultimate. I had them in my previous car and I was very impressed with them.
Old Oct 10, 2006 | 09:51 PM
I-30BLACKDEMON's Avatar
OEM are good all around generally. Espicially for if your not an aggressive driver
Old Oct 10, 2006 | 09:55 PM
PerfectVQ I30's Avatar
Im an aggressive driver and im on my second set of akebono's since i got my rotors. I love em and under hard multiple braking, they dont fade.
Old Oct 11, 2006 | 08:38 AM
clayman88's Avatar
Whats the word on ceramic vs composite?
Old Oct 11, 2006 | 08:59 AM
NewLoveI30's Avatar
OEM have trouble with material deposit on the rotors. Our undersized rotors get excessively hot and pad material is transfered to the rotor causing an uneven surface and the judder most of us have or will eventually experience.
Like I said, the Hawk HPS pads have not had much a problem with this, but I think we will have problems with just about any pad material. We really just need bigger rotors.
Old Oct 11, 2006 | 01:13 PM
i30ds's Avatar
Armed and Dangerous
Eric is speaking from a 4th gen perspective, in which case oem is the best route. But that obviously does not apply here.
Old Oct 31, 2006 | 07:26 PM
iRaMarine's Avatar
so Devon, on a 4th gen do you recommend OEM pads and rotors, or just pads?
Old Nov 1, 2006 | 08:30 AM
i30ds's Avatar
Armed and Dangerous
You could do aftermarket rotors with the oem pads just stay away from the cross drilled... go with the slotted.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
