how to clean headlights?
Old Oct 20, 2006 | 06:17 PM
anhhuy8's Avatar
i have an 2002 i35 and i need to clean my headlight. i do have some deep scratches however my hid's work 100% fine. i just need something to get rid of the scratches. i do not think i need to get rid of my whole headlight unit. some give me feedback.
Old Oct 20, 2006 | 10:06 PM
mydecember1985's Avatar
If it's Deep scratches, you're gonna need to remove your headlight, WETsand with 1000 grit, then 2000, 2500, and then as fine as around 3000(if you can find 3000 grit). Headlights will be very cloudy and hazy white. use a plastic polymer to fill in haziness.
ORRRRR... Here's the simple fix: 8-9 bucks at walmart
Use a power drill, at low speed, work a wet polishing pad back and forth. apply only little pressure and dont go very high in the RPMs on the drill.(could cause heat damage or drill to slip and damage plastic lens.
Old Oct 20, 2006 | 10:07 PM
If you want to try the first procedure i mentioned for deep scratches, Google it or research the 5th Gen forums. or the Detailing forum.
Old Oct 20, 2006 | 10:43 PM
Alright, did a search for you. This is one of the better write-ups I could dig around for. Bout the third post down in the big quote tells you all about the steps of how to do it..
http://forums.maxima.org/showthread.php?t=375480
Again, sorry I didnt reply sooner to your PM. I hardly ever pay my PMs any mind.
AaronL
Nov 15, 2020 11:52 AM
Vistance
Sep 17, 2015 05:17 AM
seesole
Sep 14, 2015 12:38 PM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
