n3985's Lighting Evolution Worklog Begins....
Old 01-19-2007, 03:35 PM
  #81
NewLoveI30's Avatar
Since he is using Aftermarket, halogen housings, I doubt that there is anywhere to mount the ballasts on the lamp.
I would just extend the wiring and mount the suckers on the flat part of the bumper just above the foglights. It's probably one of the closest locations for a clean installation.
I wouldn't worry about water as some may be thinking. Those ballasts are sealed pretty well and fording rivers is not highly recomended in these vehicles anyway.
NewLoveI30 is offline
Old 01-19-2007, 05:42 PM
  #82
大陆弟弟
n3985's Avatar
You guys make it sound harder then it is, the Denso ballasts are thin enough to just go underneath the headlight. :P
n3985 is offline
Old 01-20-2007, 05:48 PM
  #83
Got Projectors?
MetaOrbit's Avatar
As I'm sitting here staring at my PITA reflector headlights, I have to ask...have you fired up the high beam on those projector headlights to see how good its coverage is?
That's part of my motivation for using the OEM-style headlamps, in that I love the coverage of the high beam and how it floods the road with light.
Basically, I'm trying to talk myself into using the projector style lamps (though perhaps with a shroud swap)...LOL.
MetaOrbit is offline
Old 01-20-2007, 07:06 PM
  #84
nycspudz03's Avatar
Basically, I'm trying to talk myself into using the projector style lamps (though perhaps with a shroud swap)...LOL.[/QUOTE]
I have a pair for sale btw...
nycspudz03 is offline
Old 02-06-2007, 05:22 PM
  #85
大陆弟弟
n3985's Avatar
Small update:
Because I have been stranded indoors due to the weather, I've figured out that my horizontal aiming is fine by using a torpedo level. So I am going to buy some springs to hold the projector in place, seal everything together, and just install it on the car. While I was bored I wrapped the back of the "angel eyes" with metallic tape to trap as much light as possible projecting forward. While this did not do too much, the rings are definitely more defined than before, but it still leaves the fact that these LED angel eyes are dim. I have also received my Bosch mini H3 projectors and a practice fog light from Meta, so part 2 should begin soon!
n3985 is offline
Old 02-06-2007, 06:12 PM
  #86
nycspudz03's Avatar
Are the Bosch mini H3's hids or halogen?
Old 02-06-2007, 06:14 PM
  #87
大陆弟弟
n3985's Avatar
Halogen, but I am going to use my H3c HID kit in it.
n3985 is offline
Old 02-08-2007, 08:55 PM
  #88
大陆弟弟
n3985's Avatar
Here is the FINAL projector mounted onto the bracket:
From the lens inward it is bolt>projector>nut>spring>nut>bracket>lock washer>nut
And I am definitely....and finally going to seal these up tomorrow and try to get it on the car ASAP.
n3985 is offline
Old 02-08-2007, 09:07 PM
  #89
Got Projectors?
MetaOrbit's Avatar
Good to hear
Also - not questioning your approach or anything, but is there any particular reason you chose to use springs to fill the gap rather than using say, standard-length nylon spacers?
What you have works just fine (was using springs to mount my projectors) - just curious.
Old 02-08-2007, 10:54 PM
  #90
大陆弟弟
n3985's Avatar
Well all the other retros I've seen use springs to keep the tension and make sure the bolts and nuts don't move. So I just followed suit. And as for your earlier high beam question, it is just a round reflective "bowl", which is exactly the same as what the new 5 series have for their high beams, so I guess the output should be ok. And I got your PM, don't know if you received my reply, but I will take extra pics once it is done.
n3985 is offline
Old 02-09-2007, 05:43 PM
  #91
大陆弟弟
n3985's Avatar
Here they are! All sealed up and ready to be mounted and final aiming.
n3985 is offline
Old 02-09-2007, 07:18 PM
  #92
nycspudz03's Avatar
Were they painted?? color matched?..
Old 02-10-2007, 10:54 AM
  #93
romefolk's Avatar
ok i know this may sound dumb, but im looking for the least expensive with the best quality. I have a 2001 I30 with the halogen headlights.
Im and trying to do the same thing n3985 has done with his I35.
1. Because i have a i30 - where can i get the i35 HID headlights/ballast/etc. components from to swap with my I30.
2. Are there any i35s out there that came stock with HIDs and the projectors?
3. are the i35 fog lights HID too? If not how would u convert them? Please dont tell me you need a HID kit..
4. Why did N3985 get ebay projectors and TSX projectors?
5. How much would everything cost me? n3985 said $500 but i dont have the i35 with HIDs already.
Noob here!! Sorry...i have read everything from HIDplanet..but im more confused. I read everything here and im starting to understand.
romefolk is offline
Old 02-10-2007, 11:15 AM
  #94
大陆弟弟
n3985's Avatar
OK, lots of questions...
1. you can find I35 HID headlights from eBay, junk yard, or $$$$$$ from the dealer.
2. All I35s come with stock REFLECTOR HIDs, and none with projectors.
3. I35 fogs are not HID, you will need to buy a H3 mini kit to conver them.
4. I bought eBay projectors because I wanted the ease of a projector swap, rather than the full hassle of a real retrofit where I will be cutting apart a set of I35 headlights.
5. Cost will depend on how good of deals you can find on eBay and/or HIDplanet.
Lastly, I highly suggest you read the HIDs for newbies thread in the HIDplanet's HID University section. It will teach about HIDs, the differences bewteen components and etc.
n3985 is offline
Old 02-10-2007, 11:17 AM
  #95
大陆弟弟
n3985's Avatar
I *tried* to match the factory silver look of the I35 headlights, so I spray painted the inner trim with the closest silver color I found.
n3985 is offline
Old 02-10-2007, 12:13 PM
  #96
romefolk's Avatar
Thanks n3985...
I understand now! after reading HIDplanet. I think the hardest part will be finding the i35 HID assy.
would you suggest i just buy the entire i35 HID headlight assy or just the composite headlights, but im not sure if the composite headlights come with all the relays and ballast and etc that i need.
romefolk is offline
Old 02-10-2007, 12:15 PM
  #97
大陆弟弟
n3985's Avatar
Do you just want HIDs? Or projectors as well? If just HIDs, just go buy a 9006 HID kit and drop it in. If projectors, then things will get more complicated.
n3985 is offline
Old 02-10-2007, 12:36 PM
  #98
romefolk's Avatar
i want the same setup that you have n3985..with projectors. Do u have a final pic of them installed on your car, with the lights on and off?
romefolk is offline
Old 02-11-2007, 06:23 PM
  #99
Armed and Dangerous
i30ds's Avatar
wow... those look great.
i30ds is offline
Old 02-12-2007, 03:33 PM
  #100
NewLoveI30's Avatar
If you want the same set-up you should be able to follow this thread and figure it out.
You will NOT need to buy OEM I35 headlights. You will need a pair of projector headlights on ebay (or elsewhere), then some similarly sized HID projectors (n3985 used some projectors form a TSX). You will also need to find HID ballasts and bulbs (D2S), plus some relays (HID kit makers usually sell them).
Old 02-12-2007, 03:34 PM
  #101
NewLoveI30's Avatar
Those look awesome n3985. Cant wait to see some pics of them mounted and lit!
Old 02-13-2007, 12:26 PM
  #102
romefolk's Avatar
You will NOT need to buy OEM I35 headlights. You will need a pair of projector headlights on ebay (or elsewhere), then some similarly sized HID projectors (n3985 used some projectors form a TSX). You will also need to find HID ballasts and bulbs (D2S), plus some relays (HID kit makers usually sell them).[/QUOTE]
I looked on ebay for TSX projectors but how do i tell if they are oem before i buy them? and besides ebay, where would i get them? what is the price range?
romefolk is offline
Old 02-13-2007, 03:48 PM
  #103
大陆弟弟
n3985's Avatar
TSX projectors are only OEM, and please use HIDplanet for the remaining questions, it can be easily found.
n3985 is offline
Old 02-13-2007, 06:05 PM
  #104
大陆弟弟
n3985's Avatar
This is for Meta, Denso slim ballasts underneath the headlights.
n3985 is offline
Old 02-13-2007, 06:38 PM
  #105
Got Projectors?
MetaOrbit's Avatar
Nice. I take it you no longer need the measurement of the spade connector now?
Old 02-13-2007, 06:39 PM
  #106
大陆弟弟
n3985's Avatar
No, I do, I soldered on 1/4 female spade connectors to connect to the factory ballast plug. But now I think about it, I think it was smaller than 1/4.....
n3985 is offline
Old 02-13-2007, 07:33 PM
  #107
Got Projectors?
MetaOrbit's Avatar
Well the connector has two posts - one + and one -, the total width (from outside to outside is about 1/2") As for the actual posts themselves, they are definitely smaller than 1/4." I didn't think to measure those (duh), but I'd say each post is probably closer to 1/8" wide.
Old 02-13-2007, 07:42 PM
  #108
大陆弟弟
n3985's Avatar
Crap, I figured as much. Oh well, wire taps it is then. -_-
n3985 is offline
Old 02-14-2007, 11:02 AM
  #109
Got Projectors?
MetaOrbit's Avatar
I might have some spare wires/connectors...I'll look when I get home.
Also, did you add additional sealant (butyl rubber?) or just re-heat and re-assemble?
Old 02-14-2007, 11:37 AM
  #110
大陆弟弟
n3985's Avatar
Reaheat and sealed, it had plenty of sealant left....or so I think.
n3985 is offline
Old 02-14-2007, 12:16 PM
  #111
clayman88's Avatar
Absolutely beautiful!!
clayman88 is offline
Old 02-16-2007, 08:59 AM
  #112
G37S > I35 > UR Max
leeI35's Avatar
I want to see installed pics! now-now-now-now
leeI35 is offline
Old 02-16-2007, 09:28 AM
  #113
大陆弟弟
n3985's Avatar
It is 11F outside, my car is covered in 1 inch ice
You have no idea how badly I want to put them on....
n3985 is offline
Old 02-16-2007, 01:32 PM
  #114
G37S > I35 > UR Max
leeI35's Avatar
Well in that case, I can wait. I have already screwed up my stock OEM lights so, doing this projector project should not hurt anything. Can't wait to see how they look on your car.
leeI35 is offline
Old 02-16-2007, 02:04 PM
  #115
nycspudz03's Avatar
HOw? WHat happened??
Old 02-19-2007, 09:43 PM
  #116
G37S > I35 > UR Max
leeI35's Avatar
When I cleared my headlights I didn't sealed them correctly + I lost my amber reflectors and one of my HID's bulbs flickers when it heats up.
leeI35 is offline
Old 02-19-2007, 09:45 PM
  #117
大陆弟弟
n3985's Avatar
If the bulb flickers, it may because of a dying bulb or ballast.
n3985 is offline
Old 02-20-2007, 12:35 PM
  #118
01 I30 .. aka White Diamond
flewdawg's Avatar
Hey, I noticed you are using the TSX light ... Is that because it looks better, or the ebay one was cheap?
flewdawg is offline
Old 02-20-2007, 03:39 PM
  #119
Reppin' the 216
Xtr3m3X's Avatar
OMG dude those lights look sweet as f**k!!!
Xtr3m3X is offline
Old 02-20-2007, 09:10 PM
  #120
NewLoveI30's Avatar
The ebay lights come with a crappy halogen projector. The TSX projectors are accurate HID projectors. Much better light distribution and cutoff.
Quick Reply: n3985's Lighting Evolution Worklog Begins....
