Tires losing air after car sits?
My car sat for about the last week or so while I was home on spring break (I flew instead of driving the 700 miles). When I came back it appeared that my front tires had lost air. Is this common when a car sits or should I be concerned about the tires? (which were checked out as good when I had them rotated and the wheels balanced two weeks ago).
Though that's just one way a tire can lose air. For me I knew it had to be something like that because there was no visual puncture and it took forever to lose the air. I'd take it somewhere and make certain that there are no punctures, and then have them test for slow leaks. Just explain what's going on.
maybe someone let your air out.
check your valve stems- they might be corroded.
spray your tires with tire shine and try to figure out where the leak is.
if you have a discount tire co. over there i know for a fact that they fix flats for free.
Yeah the weather has been all over the place. It's not like the tires are flat either, they just appear a little low (I haven't confirmed this yet with a tire pressure gauge, just by eyeball).
Originally Posted by NewLoveI30
Fill em' up and take some readings over the next couple of weeks.
It's probably nothing.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
