Clunking noise in i30t 2000
Old Jul 11, 2007 | 04:28 PM
mohiudr's Avatar
Hi All,
At slow speed I am hearing a clunking noise from the right front. If I give more gas the clunking increases. I also feel this clunking happen going up at steep drives. I also feel like the engine is running kinda loose compared to the newer cars which seem to run tight.
Any suggestions to correct this.
Thanks,
Mohiudr
Old Jul 11, 2007 | 06:35 PM
nicnic09us's Avatar
Originally Posted by mohiudr
Hi All,
Thanks,
Mohiudr
Well for starters just changed my right front wheel bearing, it was making a sound similar to the sound u stated but more of a grinding ......and the higher the speed the higher pitched the grinding got. So i went to autozone and got a wheel bearing for like 50 bucks or so and put it in myself....rides like a champ now. *Note if u plan on doin this urself make sure u have the correct tools...i.e. crows feet, wrenches, patience....oh and of course a shop press...the bearing has to be pressed into the hub.*
And b sure to have the front end alignment done...
Old Jul 12, 2007 | 11:11 AM
mohiudr's Avatar
I was thinking this problem is something to do with timing chain or something in the engine. The sound is related with the gas you give and the low speed.
Old Jul 12, 2007 | 01:04 PM
brio_max's Avatar
Learning English...
Do you hear the clucking around 2000rpm mostly when going up hills or so?
Old Jul 15, 2007 | 11:12 PM
mohiudr's Avatar
Yes. Also when it is going on low speed
Old Jul 17, 2007 | 02:52 AM
brio_max's Avatar
Learning English...
Yeah, i've seen many people on here incl. me having the same problem. You can search the org for "rattling and knocking" and you'll se the threads i'm talking about... I think that's from the coils...
Old Jul 17, 2007 | 11:30 PM
00i30T's Avatar
Mine sounded like there was a bolt loose on the exhaust manifold or one of the heat shields at the bottom of the car, I kinda lived with it for the longest time. Same symptoms, going up or down hill in some what light to medium accelaration, and the wheels felt a little loose going through small bumps or ripples along the road.
Funny part is when I had my shocks replaced with KYB's all the noises that I just mentioned went away. I don't know if I had a bolt loose or if it what other thing it could be b/c I had my car to the mechanic once for him to figure out what the rattleing noise was coming from, and he couldn't find it, told me it was my exhaust heat shield and the only way to get rid of it is to remove the heat shields but I never did it, so in my case it was something to do with the shocks/struts.
I'll be interested to find out.
Chucky.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
