99 I30 ECU different than others?
Old Aug 11, 2007 | 11:35 AM
sicivic89's Avatar
Question: I have a 99 Infiniti I30 with the service engine light on. I read the above links where it tells you how to check the light with the blinks, etc for a 4th get maxima. But when I pulled the panel off to expose the ECU, the little white sticker is called idlespeed adjustment and then says "low - high - self diagnosis" and there isn't a small flathead screw too adjust. The sticker wasn't broken thru either. Is there something I'm missing? I was assuming the I30's and maxima's are the same. Did they change something for this year?
Old Aug 11, 2007 | 11:58 AM
i30ds's Avatar
Armed and Dangerous
Yes, the method for checking the codes it is different from the other 96-98 ECUs.
Since you have a 99, just save yourself the hassle and have Autozone check your codes.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
uttadms31
Sep 30, 2015 05:24 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
jerrod99_se-l
Sep 25, 2015 03:02 AM
