Annoying rattle
Old Jan 24, 2008 | 08:17 AM
MattB85's Avatar
Annoying rattle
When I hit a major bump in my I30, there's a rattle that seems to be coming from the dash. It sounds like it's coming from the panel above the clock, where the nav system would go if my car had that option. It's an '01 so it doesn't have the compartment there. Any suggestions as to what the cause might be? I know it's vague but perhaps someone else has had a similar experience.
Old Jan 24, 2008 | 08:28 AM
dineth00i30's Avatar
yeah my 00 does the same thing and that get soo efing annoying. mine have the storage compartment and i took everything out and it was still there now im starting to think its the the lid that is loose.
Old Jan 24, 2008 | 09:00 AM
MattB85's Avatar
The panel that contains the compartment/nav/nothing is definately removable, so I'm wondering if something either came loose or broke inside the panel and is causing the noise.
Old Jan 24, 2008 | 08:39 PM
teksurv's Avatar
I do not have this rattle, but can confirm it is easy to remove this top panel. I do have the NAV screen, still all I had to do was pull the vents below it, remove 2 bolts and lift up. Check wiring and padding maybe?
Old Jan 25, 2008 | 05:18 AM
JP11283's Avatar
Mine has the rattle on and off. I've also got the storage apartment above the clock. I can't seem to figure out where it's coming from. It is rather annoying though.
Old Jan 25, 2008 | 11:07 AM
ShippedOut's Avatar
My 01 I30 did that 2 but i found out it was just the wheel lock bolt was rolling around there.
Old Jan 26, 2008 | 03:29 PM
i took things outta mine but it was still there. also man bytheway im only 18.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
mpbclutch33
Dec 26, 2015 11:11 AM
jerrod99_se-l
Sep 16, 2015 02:39 AM
