04 I35 - Oil Pressure light on!! Help!
Old Feb 5, 2008 | 02:55 PM
GrandMoffJoseph's Avatar
As I was pulling in my driveway, the oil pressure light came on. I immediately parked the car and shut it off, and have not started it since. It is being towed into the dealership tomorrow, as it is the only shop in my area that will work on newer cars (seriously, I called around).
Any ideas what is causing this? Any ideas at all???
As the lolcats say, HALP!
Old Feb 5, 2008 | 02:58 PM
NmexMAX's Avatar
dot dot dot ...
Low oil pressure caused by low oil level (really low in order to have set off the oil pressure light) perhaps amplified by your driveway if it is an incline/decline.
Old Feb 6, 2008 | 08:48 AM
UPDATE!!
Just got an update from the dealer: Turns out my car is 2 quarts low on oil!!! And I just had it changed less than two months ago!!
No visible leaks were found, and the oil pressure sensor and pump check out. any ideas WTF is causing this? I can only assume whatever it is is costly to fix.
Old Feb 6, 2008 | 09:59 AM
n3985's Avatar
大陆弟弟
The 3.5 is KNOWN to burn oil, if you are under warranty it's time to be aggressive and request a new engine!
Old Feb 6, 2008 | 10:01 AM
Unfortunately, I'm at 77K, and thus out of warranty.
Reading this and other Nissan forums, it seems that comopression tests and PCV valves are common ideas tossed around. Any thoughts?
Old Feb 6, 2008 | 11:58 AM
NmexMAX's Avatar
dot dot dot ...
Have one performed (or a leak down test) and change the PCV, monitor oil 'consumption', and save all receipts.
Old Feb 6, 2008 | 01:28 PM
99BlackMaxMS's Avatar
3.5 > oil
No but seriously, top the oil off and check it every 500 miles to see how much you are burning. It could be some minor stuff, but most likely you have an oil burner and you never realized it.
Old Feb 6, 2008 | 07:56 PM
NmexMAX's Avatar
dot dot dot ...
Just curious, what is your build date?
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
