Minor Spring Mods!!!?@!@#!!11!!
Old Jun 11, 2008 | 01:45 PM
C P Squared's Avatar
I just got done putting on the Lamin-X and letting the clearcoat on he sidemarkers settle so I put them on and snapped a couple of pics. Comments are welcome!!
Old Jun 11, 2008 | 02:00 PM
RobertA32's Avatar
Not feelin it.
I like the clear sidemakers more, i guess the S-RT fogs looks a lot better.
Yellow/Amber lights remind me of:
Old Jun 11, 2008 | 02:17 PM
I'm also taking out the orange dome this weekend. It looks ugly. I'm going to replace them with bulbs that look silver but blink amber
Old Jun 11, 2008 | 02:21 PM
essential1's Avatar
My axles cry for mercy...
It's just my opinion, but I dont like it at all. It takes away the class from the car and makes it look tacky. It doesn't flow well. I say, ditch the yellow fog tint and get some capsules or 3000k HIDs. Just smoke the side markers some, and paint the headlight housing and grill to tie it all together.
Again though, it's not my car and if you really like it, keep it and be proud. You might have some other changes coming that will tie what you have done so far together.
Old Jun 11, 2008 | 02:25 PM
dineth00i30's Avatar
i kind of like that idea. i already have 3000k on my fogs but my cornering light is still that ugly oem color and if this make it look yellow i would do this. BTW did you buy a bulk or pre-cut? and how much and where did u get it from?
Old Jun 11, 2008 | 02:34 PM
I order it Bulk. They only had precuts for the I35 and it costs almost $200+ for film for the whole front end. I order a piece 16x7. I fit perfectly so I can handle it around the edges and not have to worry about finger prints. It costs $50 shipped for 2 sheets.
Old Jun 11, 2008 | 04:40 PM
n3985's Avatar
大陆弟弟
Good job, polish the headlights too, looks hazy.
Old Jun 12, 2008 | 10:36 AM
Does anyone have pictures of an A33 I30 with 19'' rims?
Thanks,
Chuck
Old Jun 12, 2008 | 10:48 AM
clayman88's Avatar
Sorry man...I'm not feeling the yellow fogs at all. I like the look of clear side-markers as well. I'm glad you like it though. Thats all that matters.
Old Jun 12, 2008 | 01:48 PM
I'm trying to make my car as blacked out as possible without smoking the lights or black rims. I just don't like how much the orange/clear sidemarkers standout
Old Jun 13, 2008 | 10:29 PM
Does anyone have a DIY on taking out the Orange domesin the front lights?
Thanks,
Chuck
Old Jun 14, 2008 | 06:52 PM
Norkoastal's Avatar
Thanks,
Chuck
Similar concept..
http://www.innerbean.com/housecor/clear_HIDs.html
Old Jun 15, 2008 | 06:28 PM
ZGadson's Avatar
The first thing I did when I got my I35 was take out the corners because I hate orange lights on cars. Its not exactly a simple task, but it can be done by a beginner if done correctly. I should mention that I haven't been able to find amber color LEDs that are bright enough to be seen in daylight, nor have I been able to find regular amber color bulbs that fit in that light slot, but here ya go:
1) Remove headlights (2 bolts on top, and one on the bottom which may require removal of plastic wheel well shields to access screw)
2) Remove the screw on outter end if each headlight (you'll know it when you see it). Heat lights (without bulbs) in oven on cookie sheet to make sealant between clear lense cover and black housing pliable. 300 degrees in the oven for NO LONGER THAN 45 SECONDS TO 1 MINUTE AT A TIME should be sufficient.
3) CAREFULLY pry lense away from housing at outter end (this may require repeated heating if sealant gets hard too quickly).
4) You don't have to completely remove the lense from the front of the housing - pry it away just enough so that you can pull out the amber corner insert. You may have to actually break the plastic amber piece to remove it if its stubborn.
5) Put light back in oven to warm up sealant enough to press lense back onto housing (this also may require heating several times). Put end screws back in place.
6) This is optional, but you should do it to prevent fog build up inside lense in the future: Drill 4-6 small holes in bottom of lense where it meets the housing - be carefull not to drill too far in, as you'll bust through the chrome in the lights themselves. This will allow for water to drain/evaporate in the event that the sealant doesnt completely seal.
Any questions? Zach@gadson.com if you want. I'd be happy to help.
And no, I do not still have the blue bulbs in the headlights. It looked too Honda Civic like...
Old Jun 15, 2008 | 08:32 PM
Awesome man, thanks a lot
Old Jun 15, 2008 | 11:17 PM
Norkoastal's Avatar
These should do the trick for the amber corners... lol at price though
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
You will also need a load resistor to prevent hyperflashing.. 1 for each side..
Old Jun 21, 2008 | 03:45 PM
ShippedOut's Avatar
Post night time pictures
Old Jun 21, 2008 | 07:38 PM
I will after I get the yellow blubs, you can't really tell that they're yellow at night.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
