Navigation input while in motion
Note that the navi may use the GPS in addition to VSS at normal travel speeds, the FSM doesn't really clarify which speed input it uses to lock out the screen.
Check the compatibility list, it may very well not work. Chances are just that he's not tested it, though.
VSS line is pin 14 on the back of the nav control unit, purple/red wire.
Will have to try this out this weekend and report what happens. IF it works like my other car it should give the passenger a set period of time to enter the destination before you have to re-trip the switch. I will probably mount a switch in the ashtray or something.
the OEM system uses the VSS line in slow trafic to update your point on the map. the GPS is used once you get moving.. like on a highway... so if VSS not connected then your car on the map will be off..
worldwiderecognized
Sep 30, 2015 01:16 PM
