HID fogs
Old Jul 17, 2011 | 06:50 AM
  #41
D I R T Y I 3 0's Avatar
Originally Posted by Joeker82
8k is ghey!
You're gay!
Old Jul 17, 2011 | 08:09 AM
  #42
Joeker82's Avatar
Originally Posted by D I R T Y I 3 0
You're gay!
Lol!
Old Jul 17, 2011 | 08:38 AM
  #43
CMax03's Avatar
Originally Posted by pahanorlando
Oh No! Why would I hate violet?
Cause the light Output (Lumens) is minimum and sucks!!!! 4300-8000 is the range for most. I personally like my 8000K headlight/foglights combo and light output is awesome but would be even more intense if I"d done 6000K. Usually when I pull up to a stoplight with another HID hobbyist using 10000K,12000K,or 100,000K their light output is so poor I flood their lights pattern with my own output making their lights look like they're not even on!!!!! Here's a few pics of my setup! Remember the lower the numeric kelvin the higher the lumen, The higher the kelvin, the lower the lumen!!!!
Old Jul 17, 2011 | 10:58 AM
  #44
pahanorlando's Avatar
Looks nice. Do you think 12k will be brighter than stock fogs?
Old Jul 17, 2011 | 10:59 AM
  #45
VQ'rInWLA's Avatar
Did you miss what we all said up top?? 12000k is dim.
Old Jul 17, 2011 | 11:07 AM
  #46
So dimmer thank stock?
Oh sheeeeet!!!!
Old Jul 17, 2011 | 11:14 AM
  #47
damienjacab's Avatar
i got a 5000k 35w xenon foglight kit to match my headlights on my 08 Max shipped for $59.99 on hidextra.com and havent had a problem with them and ive had them for 7 months
Old Jul 17, 2011 | 11:18 AM
  #48
VQ'rInWLA's Avatar
WAY dimmer than stock. Its good to look at from outside but output wise it sucks
Old Jul 17, 2011 | 12:35 PM
  #49
I see, well, I could always replace the bulbs later.
Before I get the kit to my door,
I was wondering, how did you guys do the installation?
Did you keep the stock cap? did you had to cut something from the HID bulbs?
Old Jul 17, 2011 | 03:18 PM
  #50
Joeker82's Avatar
Dude, you really got to search more on the site. All of this has been covered before. TRY SEARCH!
Old Jul 17, 2011 | 04:33 PM
  #51
CMax03's Avatar
yes brighter than halogen but no where as brilliant as stock HID's (lumen wise)!!!!!
Old Jul 17, 2011 | 04:38 PM
  #52
CMax03's Avatar
This kelvin for instance lays down good light coverage with good intensity and solid lighting, a very good lumen rating!!!!! Stay away from anything above 8000K it just looks cool and doesn't emit any intensity and don't let it rain cause you won't see anything on that wet ground cause it's too dim!
Old Jul 17, 2011 | 05:12 PM
  #53
VQ'rInWLA's Avatar
I have some 6000k bulbs but theyre h7. If your fogs have that little clip that hold the bulb in place, these would fit. Looking to sell for $16 shipped
Old Jul 17, 2011 | 05:42 PM
  #54
I did search. One guy did it with the stock fog cap and you removed the cap I think so I was trying to find out what is the best way.
Should i do it like the guy did it whose name starts with n? The guy that draw the wiring diagram
Old Jul 17, 2011 | 06:15 PM
  #55
Jaidon05's Avatar
I want to do this mod is this hard to do? I have an non Hid headlight that I wanna swap to HID.
Old Jul 17, 2011 | 06:16 PM
  #56
VQ'rInWLA's Avatar
Not hard at all. Plug and play.
Old Jul 17, 2011 | 06:23 PM
  #57
Joeker82's Avatar
Put the cap on. If not, you'll get moisture in the fog. You have to modify to fit the cap.
Old Jul 17, 2011 | 06:48 PM
  #58
Jaidon05's Avatar
For headlights and fogs?
Old Jul 17, 2011 | 06:57 PM
  #59
VQ'rInWLA's Avatar
Yup if you get the right size so connectors remain compatible.
Old Jul 17, 2011 | 07:18 PM
  #60
knightowl's Avatar
I make a lot of runs down I80 in PA and find 8k head/fog to work great on the unlit roads no need for brights
Old Jul 17, 2011 | 07:50 PM
  #61
CMax03's Avatar
Are you two referring to the seal on the rear access cap.....If you are I drilled my rear cap with a uni-bit til my HID foglight bulb's seal fit perfectly! Here's some picture for some insight!
Old Jul 17, 2011 | 07:51 PM
  #62
Jaidon05's Avatar
Thank you, off to go find some stock replacements. I hate driving at night due to poor visibility. Can someone spare some advice where to look to upgrade both headlights and fogs? Do I need projectors?
Old Jul 18, 2011 | 09:13 AM
  #63
Would you recommend to take all fog light assembly out?
Old Jul 18, 2011 | 02:18 PM
  #64
Joeker82's Avatar
Yup, under the front of the car is plastic splash guards. Remove those and you will see the back of the fog housing. I believe there is one screw holding the fog light assembly in place. (10 mm?) Once you remove this, the whole assembly will be able to be removed from the front of the bumper.
Old Jul 18, 2011 | 05:40 PM
  #65
CMax03's Avatar
Here's my kit!
http://www.xtralights.com/waterdemo.aspx
Old Jul 18, 2011 | 11:41 PM
  #66
ef9's Avatar
ef9
100% water proof, not just splash proof!
Old Jul 19, 2011 | 09:04 AM
  #67
spreenyk888's Avatar
for people with hid fogs, where did you mount the ballast? i extended my wires up and tucked the ballasts in behind the headlights. im just wondering other places you put it.
i also agree with the 8k ftw....i have that in my headlights, and 6k in the fogs. 12k is gonne be super purple. ew.
oh, and i also use those xentec kits off ebay. $33 and they work just as well as anything else.
Old Jul 19, 2011 | 11:23 AM
  #68
VQ'rInWLA's Avatar
Mounted mine in the area behind the fog above the splash guard.
Old Jul 19, 2011 | 12:04 PM
  #69
I don't know how you guys did it, but I H3 bulbs did not work for me. They are too long. The only way to make them fit is remove the reflector inside the fog assembly, but I think the lighting might not be as good if you remove the reflector. So I will have to order H3S bulbs, and it won't be violet I think I'll get 3000k yellow
Old Jul 19, 2011 | 12:05 PM
  #70
VQ'rInWLA's Avatar
Match it with 6000k IMHO
Old Jul 19, 2011 | 12:09 PM
  #71
Okey, thanks, I will
Old Jul 19, 2011 | 01:05 PM
  #72
Joeker82's Avatar
Really!?! Mine fit just fine with the reflector in it. Even though I removed mine. ( personal preference)
Old Jul 19, 2011 | 02:43 PM
  #73
mine fit too with the reflector.....but i also took the reflector out.
Old Jul 19, 2011 | 02:47 PM
  #74
U both have i30?
Old Jul 19, 2011 | 02:53 PM
  #75
Joeker82's Avatar
U both have i30?
It's the same housing for the I30 and the I35
Old Jul 19, 2011 | 04:59 PM
  #76
How come mine doesnt fit lol
Old Jul 19, 2011 | 05:07 PM
  #77
VQ'rInWLA's Avatar
No wonder why she stopped answering your calls....with statements like that
Old Jul 19, 2011 | 05:13 PM
  #78
LOL, nice one. It took me over a minute to get it though
Old Jul 19, 2011 | 05:14 PM
  #79
Joeker82's Avatar
Thats what she said! ( nicely played)
Not sure, I'm starting to think with all your problems...maybe, your car was built on a friday at 5 pm. Lol!
Old Jul 19, 2011 | 05:23 PM
  #80
VQ'rInWLA's Avatar
