2001 infiniti i30t amp installation
Old Feb 21, 2012 | 04:18 PM
jon1986's Avatar
hey my stock bose sub went out, so i bought a aftermarket sub and amp, got the wiring kit, and a line out converter. im a total noob, but i want to learn how to do it myself instead of pay 100-200 bucks for installation. i have a stock h/u and speakers... where from here? lol
Old Feb 21, 2012 | 05:53 PM
AznRyan's Avatar
Here's a couple very useful threads with info about replacing the Bose system.
http://forums.maxima.org/infiniti-i3...ould-nice.html
http://forums.maxima.org/audio-elect...thread-20.html
Unfortunately for us Bose-ians, we gotta replace the entire system - speakers, sub, amp, and head unit.
Metra makes a good dash kit (and I think someone said the GXE trim can be used for a flusher install) for double din head units.
Edit - another Bose thread, which might help your cutout problem without spending the money to replace hardware
http://forums.maxima.org/5th-generat...l?ref=esp-link
Old Feb 21, 2012 | 06:15 PM
jon1986's Avatar
basically...
i want to know if i can use the wires that go to the stock bose amp and connect them to the new amp while leaving the stock amp to power the stock speakers... or if i could just remove the stock amp and just use the new amp to power the sub and speakers using the wiring that is already in place.
Old Feb 21, 2012 | 06:22 PM
AznRyan's Avatar
I asked something similar to a Crutchfield audio tech. and got this in reply;
"Ryan, You can always add an amp and sub to a factory system by tapping into the left and right full-range speaker wires for input, using an amp with speaker-level inputs, or adding a line output converter. The factory subwoofer in your Infiniti's Bose system is self-powered, getting a line-level input from the amplifier, which runs the four door speakers. If you want to replace the factory sub, you'll need to add an amp to drive it."
Old Feb 21, 2012 | 06:31 PM
jon1986's Avatar
ok, i already have a new amp and a line output converter... just need to know what wires to connect to it, lol, like i said im a total noob...
Old Feb 21, 2012 | 08:04 PM
AznRyan's Avatar
Going to one of the links I posted (2nd post in this thread) would get you a better answer. There's people in there much more knowledgeable than me. You might wanna ask a member here by the name of djfrestyl , he knows his stuff, and is a very helpful member. Either private message him or leave him a message on his profile
On another note, djfrestyl also makes a replacement for the spare tire cover. Very reasonably priced, professionally made, and a huge improvement over the cheap, saggy OEM spare cover. I got one in my trunk :]
Good luck with your audio install!
Old Feb 21, 2012 | 09:25 PM
pahanorlando's Avatar
This article should help you. It tells what wire you need to find
http://www.vqpower.com/v2/articles.php?article_id=9
Old Feb 21, 2012 | 10:44 PM
jon1986's Avatar
for sure, thanks for the replies
Old Feb 22, 2012 | 12:33 AM
2brosgixxer's Avatar
How were you able to post a new thread without having 15 posts?
Old Feb 23, 2012 | 03:04 PM
jon1986's Avatar
i have no idea... lol
Old Feb 25, 2012 | 03:12 AM
jon1986's Avatar
ok so now that i know what needs to be done for wiring... anyone have any mounting suggestions.... i have decided for convenience i want the amp in the trunk... just don't know where...
Old Feb 25, 2012 | 03:30 AM
On my 4th gen maxima, I mounted mine upside down on the deck between the 2 factory rear speaker locations. Others have mounted on the trunk lid, the side of the trunk and to the speaker box directly. I like being mounted on the deck so If I need to take the sub out, I only need to remove the speaker wires from the box and not mess with all the wires going to the amp. I can snap a pic if u need one.
Edit: give me a few minutes and when I leave work, I'll snap a pic and upload it for you. Don't make fun of my amp tho, its old but it works LOL
Old Feb 25, 2012 | 10:11 AM
AznRyan's Avatar
If the amp isn't too big, how about in the area where you Bose amp is?
Should be on the underside of the rear deck (to the right of the "sub", if you're standing behind your car)
Old Feb 25, 2012 | 10:58 AM
I believe he's keeping stock speakers and amp.
Old Feb 25, 2012 | 04:51 PM
AznRyan's Avatar
Old Feb 25, 2012 | 08:41 PM
jon1986's Avatar
well, after a lot of reading i know i have a 5th gen bose system, so the sub is self amped, and the amp that i had thought was the sub amp, is the amp for the front and rear speakers. i don't have the money to change out everything and just gut the system, and i plan on trading this one in for something i can take offroading in a year or two once i can afford monthly payments, and i would like it to easily be returned to stock when that time comes, so i have no other choice than to keep the bose amp in there...
however, i am taking out the stock sub, so i guess maybe it could go there...
i heard that its bad to put the amp upside down or flat because it can overheat... its a class d, brutus hiphonics 1200 watt amp... will overheating be a problem if it is mounted upside down?
Old Mar 31, 2012 | 11:34 PM
laststop's Avatar
Metra makes a good dash kit (and I think someone said the GXE trim can be used for a flusher install) for double din head units.[/URL]
Any info on this gxe trim and how to use it in an i30?
Old Apr 15, 2012 | 07:34 AM
Darkstonian's Avatar
Class D amps don't really get too hot since they are digital, and they have overheat protection. I've done this already to my 2001 I. I have a 500watt Alpine MRP-M500 class D amp. I mounted it on back of one of the seats so I can make easy in cabin adjustments just by pulling the seat down. And I have a stock bose system w/navi system, so I only added a sub too. Have a small 8' for right now in a sealed box (two small children, and a wife telling me to turn it down, ) I used a PAC AOEM-NIS2 converter because it has RCA outs. Simply mounted that behind the head unit itself in the dash. You can use a line converter and tap into the front door speakers, but when I did it gave me some extra whine during acceleration. If you want, I can take some pics to show you how I wired everything up. Though not of the PAC, I'm not pulling that sh*t out again, lol.
Old May 7, 2024 | 01:39 PM
Dirtydoug's Avatar
Rear sub for a 2000 I30
How do I unhook the spearker wire. It has some strange clip.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 3, 2015 05:18 AM
Lowered_a33
Sep 1, 2015 07:49 PM
