headlight problem
Old Feb 23, 2012 | 08:03 PM
spreenyk888's Avatar
headlight problem
my driver side headlight keeps going on and off....so i changed the bulb. still doing it. it only shuts off on bumps or if i hit the headlight. standing idle itll stay on no problem. i flick the lights off then on, and it goes back on right away. this doesnt sound like the ballast to me. anyone have any ideas?
Old Feb 23, 2012 | 08:06 PM
Have you check your headlight fuse?
Old Feb 23, 2012 | 08:14 PM
i have not. guess ill check tomorrow. are there seperate fuses for the individual headlights tho? bc the passenger light is fine....
Old Feb 23, 2012 | 08:18 PM
They're separate.
Old Feb 23, 2012 | 08:22 PM
They're separate.
awesome thanks. hopefully thats the problem ill check it tomm.
Old Feb 26, 2012 | 01:33 PM
mikea1977's Avatar
ground wire?
Old Feb 26, 2012 | 03:05 PM
burgy's Avatar
HID's? may want to check your Ballast.
Old Feb 26, 2012 | 11:03 PM
CMax03's Avatar
Connection loose if it is bump or vibration sensitive!
Old Mar 20, 2012 | 01:01 PM
i finally i got a day off to check this headlight out. i took the light off, double checked every connection. checked the ballast. put electrical tape around one wire inside of the light just to be sure. its still doing it. the fuses are fine. what else could it be? i cant think it would be a bad ballast if everytime i hit a bump it goes off and comes right back on when i flick the switch.
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
