Weird car problem on start up
Old Jul 1, 2012 | 02:03 PM
pahanorlando's Avatar
Well, I haven't used my car for over two weeks and decided to start it. The engine was cranking for about 3-4 minutes with no start, then it made some thumbing noise and battery got weak by that time.
I jump started the car, same problem, waited a minute, jump started and engine finally turned on.
So what do you think was the problem? It wasn't bad battery as I was able to crank it for 3-4 minutes and probably could of longer.
It seems like fuel was not getting where it was supposed to immediately. Do you think there is something I should be worried about? May be something about to go bad?
No codes, no engine light.
After I waited idle about 5 minutes, I was able to start it again with no issues.
Old Jul 5, 2012 | 06:26 AM
2001i30's Avatar
most mornings my I30 doesnt start the first time I try to start it. the second time it always starts. I was told on a different forum that its probably caused by a leaking fuel pump, which allows the fuel pressure to drop, which is very common on these cars. He suggested to leave the key in the ON position for 10-15 seconds to build up pressure. Perahaps you had a more severe case of this.
Old Jul 8, 2012 | 10:30 AM
Thanks a lot! I had the car in ON position for sometime though.
I wonder, you think it could be bad fuel injector? may be I need fuel injector cleaner?
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Jcof88
Aug 3, 2015 10:43 PM
