help! no turn signals
Old Sep 15, 2012 | 07:06 PM
I30boi's Avatar
so i tried to drive my 2001 i30 and the.turn.signals nor the hazards work.
i am guessing its the relay because the fuse inside the car seems fine
also
i have found many relays and unplugged them but nkne that i think are the flasher relay. iv looked up its location via google and im still unsure where this flasher relay is.
every relay i have found in my car is 4 prong i called
autozone
Old Oct 9, 2012 | 09:37 AM
pat6290's Avatar
It sounds like the relay...The relay controls a surprising amount of electrical components. My old grand am used to click on its own and the signals were all screwed up until i replaced it. My Montana had a slight glow on the rear bulbs because the relay was messed
Old Nov 9, 2012 | 07:22 PM
97maximachief's Avatar
Make sure that your hazard light switch/button is plugged in. I took the console apart to install a headunit and forgot to plug it in all the way. The signals won't work if it's not plugged in.
Old Nov 12, 2012 | 08:43 PM
dewmax007's Avatar
Before you bother to mess with the relay, check carefully the fuses UNDER the hood. I had a similar experience where i lost my blinkers, hazards and you if check carefully most likely your taillights too. The fuse marked tail was out. Once replaced? Presto, all on again.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
