bose sub finally started to cut out...
Old Aug 28, 2013 | 09:19 PM
cheech_11's Avatar
so it finally happened. my bose sub is cutting out more and more often now. but i did notice than everytime i had something big in the trunk that seemed to push against the sub or the wiring that it worked just for fine for hours and hours. like i just went back to school and drove to myrtle beach from long island and has tons of stuff in my trunk and the sub worked all the way down but as soon as i unloaded my car it stopped working and went back to only working for a little bit when i hit the bottom of it. yes i know theres tons of threads on this and iv read them all im just venting lol
Old Aug 31, 2013 | 09:53 PM
cheech_11's Avatar
but whats this cardboard trick iv heard of?
Old Sep 3, 2013 | 08:44 AM
DennisMik's Avatar
You open up the subwoofer box and fold up a piece of cardboard so that when you put the cover back on, the cover is pressing the cardboard onto the relay that is in there.
The relay needs to be re-soldered (maybe replaced) but the pressure keeps it in contact with the printed circuit board. This "trick" will work for a while, but eventually the problem comes back.
This thread talks about fixing the problem properly by soldering. It has photos but a word of caution - each year of the sub looks different. So yours may not match the photos. The relay problem is the same, just located differently.
http://forums.maxima.org/5th-generat...01-maxima.html
Search the 5th gen Maxima forum for cardboard to read more about this.
Old Sep 3, 2013 | 09:37 AM
cheech_11's Avatar
thanks alot!
Old Sep 17, 2013 | 10:54 AM
thebaker's Avatar
That sucks
I have one lying around and could get it to you for pretty cheap if the cardboard fix fails.
Lemme know.
Old Apr 25, 2014 | 08:46 AM
Nolox4's Avatar
Finally
After being an owner since 2010 I have fix this issue with the cardboard trick what a relieve now I have 2 12"s connected rite to the bose sub
Old Jun 10, 2014 | 11:28 AM
cheech_11's Avatar
i gave up on fixing it lol just got a 10"
Old Jun 11, 2014 | 12:39 PM
03_I35's Avatar
Do you have an I35? If so, how/where did you hook up to the BOSE sub, and what is the OHM rating of the speakers you're running? I am fairly skilled when it comes to physically wiring things up, but I'm a dummy when it comes to figuring out the how, why, and where to make things work.
Old Sep 15, 2018 | 02:43 PM
Killian Tyler Baptiste's Avatar
Cardboard trick works great! Can't screw black cylinder back in
So I did the cardboard trick and the bass is working great. However, when i try to screw the black subamp holder it pushes up on the sub and does not allow it to hang and viabrate.
Currently the black thing is hanging by the green and red wires instead of being screwed in... Which is bad. How do i put it back in properly? How'd the factory do it in the first place?
Old Oct 26, 2018 | 06:34 PM
sparksI35's Avatar
i literally just got done doing this. You may have the silver case that the circuit board is in upside down. The bose sticker with the vent holes should be facing down inside the black cap.
arman
Aug 24, 2009 05:48 AM
zgrm100
Feb 23, 2006 08:22 PM
MaxedOut97SE
Jan 31, 2005 08:50 PM
darrelfsu
Jun 29, 2004 04:44 AM
Luke Moore
Jun 17, 2002 11:12 PM
