Replacing brake light bulb
Old Jan 13, 2014 | 11:16 AM
thenewguyy's Avatar
Hey guys,
Ive looked all over and surprisingly have not found anything on this but is there a DIY on replacing the brake light bulb on a I35? Its the driver side outer tail lamp
Old Jan 13, 2014 | 11:18 AM
Amerikaner83's Avatar
it's similar to the maxi.
Open the trunk, there should be an access panel if you pull the liner back.
Old Jan 13, 2014 | 11:48 AM
Joeker82's Avatar
It pops out from the top. Grab both sides and pull/slide towards the front of the car.
Old Jan 13, 2014 | 12:49 PM
thenewguyy's Avatar
Are there tabs or anything of that sort I should look out for? Dont wanna yank hard on it and damage it.
Old Jan 13, 2014 | 01:02 PM
Joeker82's Avatar
If I remember correctly...it is a little stubborn, but will give.
Old Jan 13, 2014 | 10:23 PM
MaxMike93's Avatar
I believe you push the housing towards the back window, then lift up from the side that faces you. Then there are five separate T10 (194/168) bulbs that twist out and you replace the ones that are burnt out.
Old Jan 14, 2014 | 04:21 PM
chrome91's Avatar
i believe after you take the cover off in the trunk, theres tabs on each side you press and the plate should pull out with all the bulbs and you just unscrew which one needs replacing
doubt the tabs will break, you would have to really force them hard. if theyre stuck just gently wiggle the plate and it should come out
Old Jan 14, 2014 | 05:56 PM
MaxMike93's Avatar
This is how they tell you to remove the assembly if you get the cover when you install a rear spoiler on an A33. The bases that you unscrew for the bulbs are on the bottom of the housing.
http://www.flickr.com/photos/97860483@N02/11956944803/http://www.flickr.com/photos/97860483@N02/11956944803/]image[/url, on Flickr
Old Jan 14, 2014 | 07:17 PM
Joeker82's Avatar
I stand to be corrected. You push towards the window, not pull!
Old Jan 15, 2014 | 09:01 AM
thenewguyy's Avatar
ok guys i will look into that but something strage is happening, I notice it doesnt light up when pressing the brake but the lights are on when no brakes are applied. Are there a different set of bulbs that light up, as in normal mode vs brake being applied?
PS. its the driver side far left tailight not working, not the center mount like the pic posted up above
Old Jan 15, 2014 | 09:53 AM
Joeker82's Avatar
That could possibly be the brake light switch/trigger behind the brake pedal...
Old Jan 15, 2014 | 12:23 PM
thenewguyy's Avatar
So I did a quick search on this brake light switch trigger which I had no clue of but according to this thread http://forums.maxima.org/5th-generat...ht-switch.html someone else posted a similar scenerio as in only the driver side tail light not working ad he was told that if the brake switch trigger isnt working then none of the tailights would be working so that takes that out of the equation
Old Jan 15, 2014 | 07:13 PM
Dual filament bulbs... like the 1157 light up dim when parking lights on and bright when brake pressed.... yes one can go out and not the other.
Old Jan 16, 2014 | 04:40 PM
MaxMike93's Avatar
Oh wow, I have no idea whey I kept posting about the center high mount light, so I apologize for that. As posted, you take out those screw-pop things then pull the liner back. One of them is popping off half the cargo net hook (you'll see a little slot to put in a screwdriver for leverage). Then you twist the socket counter clockwise (top one on an I35) and that gets you to the bulb. I don't know if the bulb is the same as an I30, in which case I believe it was a wedge-style (pushes into the socket) 7443 (perhaps a 3157 also works?). If it's a bayonet style bulb (circular base that screws into the socket), then it would be 1157.
Old Jan 17, 2014 | 06:32 AM
thenewguyy's Avatar
Interesting... Acording to sylvania https://www.sylvania.com/en-us/appli...l=1099&make=41
they say its 7443
haha no worries, yea ill look into this, thanks.
homeyclaus
Sep 3, 2015 06:15 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
MikesChevelle
Aug 6, 2015 11:36 AM
