does I35 driver door harness are the same as I30?
Old Apr 24, 2014 | 07:33 PM
infinitijohn's Avatar
Hello guys need some help
I brought a 2000 I30
I figured out that the car was hit in the left side by previous owner and theyraplaced these door by 2 I35 door on the left side,
nothing was functioning in the rear driver,when I tried to see what is wrong with that door,I figured out the harness was not connected and the I35 door harness connector was different to the I30 ,I went to the Junkyard today and brought a 2000 maxima harness for the driver rear door,everything is working now in that door
Now my main Issue is the driver door,
1-the power lock don't work in master switch but it works in the passenger side,the passenger side is able to lock and unlock all 4 doors
2-It can only control 3 power window Drive side and 2 passengers side
What you think I should do, Should i buy the driver door harness and replace it
Old Apr 26, 2014 | 01:52 AM
DennisMik's Avatar
It is possible that the harness was damaged, but it could also be the master window switch in the driver's door too. It's pretty hard to figure out which is bad. The harness can be inspected for damage, but the switch would have to be swapped to see. As a pure guess, I think the switch is bad.
As far as the wire harness goes, in the Maxima, 2000 and 2003 are not the same wire harnesses because the switches are different. In fact 2000, 2001, 2002 and 2003 are all different from each other, the switches and harnesses changed each year. I think the electrical plugs are the same, so it is possible to put the wrong harness and switch together.
Old Apr 26, 2014 | 05:05 AM
ok thanks I will try today ,I brought a 2000 front door harness, and I already had a 2000 master switch,I will let you know
Old Apr 26, 2014 | 08:02 PM
power lock resolved
I'm so Happy ,I fixed it.now my power door and lock are working perfectly ,the harness was wrong, the I35 driver door harness is not compatible with the I30
@DennisMik you were right bro, thank you for you help
Old Apr 27, 2014 | 12:06 AM
DennisMik's Avatar
I'm glad you got it fixed. Sometimes these electrical problems can drag on and on. You did the analyzing and pretty much zeroed in on it.
9aj9
Apr 5, 2020 12:11 AM
JoshG
Sep 5, 2015 10:10 PM
