Bad Head Gasket, Water Pump, or Thermostat?
Old Jan 21, 2018 | 04:04 PM
TheGodDerp's Avatar
Hey guys, I'm usually around the third gen forums, but i recently bought a 1998 i30.
I've been seeing the car heat up recently, mostly when it's sitting in traffic or idling while facing uphill (I live in San Francisco where all the hills are steep), and then the temp falls back down when the car starts moving again. Sometimes it heats up while moving, but cools back down again. Also, the fans are on all the time, as long as the car is running.
There's no check engine light as far as I know.
I haven't seen it blow any smoke so far, but I want a second opinion, just in case the inevitable happens. Have any of you guys seen this happen before?
Old Jan 21, 2018 | 08:10 PM
DennisMik's Avatar
Sounds like the engine coolant level in the radiator is getting low. Park the car on level ground and when the engine is cold, remove the radiator cap. The radiator tank should be 100% full.
If you have to add coolant, leave the radiator cap off and start the engine. If the radiator tank is empty, add just enough coolant so that the bottom is covered. Let the engine run until the thermostat opens. When the thermostat opens, fill the radiator all the way to the top.
Old Jan 22, 2018 | 11:22 AM
TheGodDerp's Avatar
Looks like the low coolant was the issue, but I replaced the radiator cap as well (for safe measure).
Old Jan 23, 2018 | 12:32 PM
JvG's Avatar
JvG
You need to ask yourself why the coolant is low.
monitor the coolant level. If it drops, something is leaking.
By the way, you will find more activity. In the 4th gen Maxima forum.
Old Jan 26, 2018 | 01:08 PM
95maxrider's Avatar
Lightly modded
It could have been a slow leak from the rad cap if the rubber was cracked, I had that happen on my 3rd gen. Burp the system well with the front end lifted off the ground to make sure you get any air pockets out of it, make sure both rad hoses are getting hot, and make sure you're getting hot air from the interior vents. Head gasket failure isn't common on these cars, so cover the basics first.
QueensMAX
Oct 26, 2014 05:14 AM
rebal469
Aug 16, 2013 11:00 AM
7mJoe
Mar 13, 2012 07:45 PM
915Max
Jan 12, 2007 05:42 PM
