Looking to do my rear control rod lateral link and suspension member bracket bushings my problem is locating the suspension member bracket bushings they are the bushings for part #19 I'm not sure if the bushings come on this part or I must order custom bushings can somebody with knowledge on this topic please help me I can cash app you $ if you help me find the bushings for part 19 Part number 19 I need the bushing that connect to the frame can anybody help me please or is familiar with this job thank you
Since #19 encompasses both the member and the bushing, and there is no separate part number for the bushing, that likely means you can't buy that bushing individually and will need to buy an entire new member if you want a new bushing. Alternatively, you can remove the member from your car and fill the voids in the rubber with polyurethane bushing mix to stiffen it back up.
How bad is the bushing on your car, can you post a pic? If you're set on fixing it, then I recommend removing the member from the car, drilling some holes in the bushing, and filling it with some poly to fill the voids and stiffen it up.
