low oil pressure issues with VQ30DE
Old Apr 12, 2015 | 12:03 AM
Gsekhon's Avatar
Hi guys,
Thrilled to be here! First thread post.
I own a 01 maxima anniversary edition.
I am experiencing low oil pressure when I turn the ignition on and it goes away after that.
I replaced the oil pressure switch and it is still an issue.
Want to see if anyone else had an issue like that with their VQ30DE.
Before I take the car to the dealership for a diagnostic check, I would like to get to know some past experiences you guys had.
thanks in advance!
Gurpreet.
Old Apr 12, 2015 | 12:40 AM
chrome91's Avatar
any timing chain noise at startup?
or do you mean the oil pressure light comes on very briefly at startup? thats normal because for a split second after startup the engine has low oil pressure until it builds up
Old Apr 12, 2015 | 09:31 PM
Gsekhon's Avatar
thanks
Hi! There is no timing chain noise at all
Yes exeactly the light comes in briefly for 2-4 seconds Max and turns off.
That's a relief if it is not an major issue.
Plus the engine has around 280k kms on it.
Thanks again for the reply.
Old Apr 12, 2015 | 09:34 PM
chrome91's Avatar
2-4 seconds is a tad longer than normal, might be the oil pump a bit worn or excessive bearing clearances but with 280,000km and running fine after startup i wouldnt really worry
Old Apr 13, 2015 | 06:39 PM
Gsekhon's Avatar
[QUOTE=chrome91;9038929]2-4 seconds is a tad longer than normal, might be the oil pump a bit worn or excessive bearing clearances but with 280,000km and running fine after startup i wouldnt really worry
Chrome91 thank you for that!
I'm going to post another thread to see what kind of suspension setup and aftermarket parts fellow owners are using. (As this is my first car and tune).
MAXSE5SPD
Sep 17, 2022 04:00 AM
cruce91
Sep 20, 2015 10:23 AM
sdotcarter
Sep 2, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
