Newbie with cooling fan problem
Old Sep 5, 2020 | 05:43 AM
Mikeyk9's Avatar
What's up guys.... So I have 4th gen 5spd that I've owned for almost 2 years and 40k miles. Every time I do research this forum pops up and I like what I see so I joined it. I've done a fair amount of work to my baby and most of it myself.... She's flat black with dual exhaust with cherry bomb glass packs.... She sounds great! So my problem is this..... I recently had a starting problem due to a damaged front CPS replaced it and fixed that problem but the next day my starter burned out from the extra strain prior to the CPS being replaced so I put a starter in.... So now as I sit in the hot sun waiting for someone I turned on my A/C only to find that the compressor wasn't kicking on. I've had a small coolant leak from the radiator for a while but the A/C always cranked since putting in a new compressor so what I saw when I open the hood was that my cooling fans weren't kicking on anymore and I was starting to overheat. I've checked the fuses, made sure all the wires are plugged in properly and I'm assuming that I would have had to have all 3 relays crap out at the same time for neither fan to kick on on low or high speed. I've also checked the CTS and that is also functional..... Any ideas? While I did have to move the main wiring harness out of the way of my starter I did not have to put any serious pressure on it. I also did not disconnect the battery right away and got a quick tiny spark but I'm figuring if I fried the computer there would be many more problems if the car would even start in the first place.....
cp318093
Jan 3, 2018 10:24 PM
MechanicalAnt
Jan 6, 2005 01:51 PM
grody
May 23, 2004 05:04 AM
JOMAN
Jan 22, 2004 12:34 AM
bshutson
Dec 3, 2003 09:09 AM
