starter problems
Old May 21, 2004 | 04:23 PM
grody's Avatar
starter problems
Hey all, I've got a couple of issues with the Max.
First, I can't get it to start. It seems to be getting spark and fuel, and I've checked all the fuses and fusible links that I am aware of, and I replaced the cap and rotor. I've checked ignition coil, power transistor, and plug wires. If I give it some gas, I'll get a backfire. It quit running after driving it in some pretty hard rain and some decent sized puddles.
Second problem which has me annoyed is that the starter isn't engaging the motor. It will spin up just fine, and the battery is in good shape, but the starter won't turn the motor over.
Anybody have any ideas?
Old May 21, 2004 | 09:56 PM
MaximamixaM's Avatar
I'd get a new distributor cap and rotor. I'd try starting it in neutral as well as park. Make sure all fuses are good. Various starter/ignition relays can also be a problem. Make sure the CEL illuminates when attempting to start the car. When I looked up various causes of starting problems those were mentioned. Try pushing forward on the shifter lever. Consider starter, starter relay aka interupt relay, ignition switch, park neutral position safety switch, engine cont relay, egi relay. Those are some various problems on a google nissan maxima group site archive. Don't know how accurate/exact they are.
Old May 23, 2004 | 04:29 AM
internetautomar's Avatar
mod or sell?
Can you say bad starter solenoid?
You may be able to buy it seperately but most places only have it already attached to the starter and sell it as part of the starter.
oh. and of course that would prevent the car from starting.
Old May 23, 2004 | 05:04 AM
CandiMan's Avatar
Say Candyman 5 times
I want you to listen to yourself. First you say you're having a starting problem but you're getting spark and fuel. Then you say you're also having a starter problem, it's not engaging the motor.
Ok let's decipher this. Could it be your stater is casuing you to have a "starting" problem? Fix the starter problem them concentrate on the starting problem.
But
Then you mention you're getting spark and I now for sure you if you're getting spark that means your starter is working.
Which one is it, a "starter" or a "starting" problem?
MIKE
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
jwright36
Sep 8, 2015 11:45 AM
