2012 Maxima tensioner question
Old Dec 18, 2024 | 12:01 PM
dntoearthman's Avatar
2012 maxima V6. G Son car -Water pump gone bad I have read to remove tensioner assembly and compress piston. I assume it needs to be reinstalled prior to rotating engine to get slack in chain for water pump removal Thx much mike
Old Dec 31, 2024 | 07:19 AM
CMax03's Avatar
You can loosen it to bleed off the oil pressure and push It back with a screwdriver then install a clip or thump tack to lock it in place. Please use caution and place a rag below it or you could drop something down inside the timing cover! Remember to back the crankshaft backward (CC) a few degrees to provide sufficient slack to remove the Water pump from the chain. Also be sure to have some jack screws/bolt ready to aid in the removal of the pump!
Old Dec 31, 2024 | 09:35 AM
. Thanks. Got it done 👍
Old Oct 10, 2025 | 03:07 AM
Georgusmut's Avatar
My Sites
рацикульжизнÑюрпÑемьзапизапижизнритмокрупоÑлÑобо
mark217
Aug 7, 2022 10:33 PM
Carrerad
Oct 20, 2021 03:49 AM
Longpockets
May 17, 2020 12:23 PM
SleeprLegend
Jul 28, 2015 03:50 PM
hacim105
Aug 19, 2006 07:59 AM
