PDA
View Full Version : 4th Generation Classifieds (1995-1999)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
  1. MD FS: 1998/99 I30 clear tail light
  2. wtb: i30 front factory floor mats (beige/tan)
  3. MN WTB: Cheap BOSE Headunit
  4. NJ looking to get a after market Exhaust( muffler,mid pipe))
  5. PA WTB:1997 Front/Rear bumper, hood, and trunk lid in black (Philadelphia, PA)
  6. VA WTB: Left R34 headlight
  7. RI r34, i30 autodimmer, iacv adapter plate... and more
  8. MN WTB Front Strut bar
  9. CA WTB SHIFT LINK
  10. TN FS: I30 fuel door actuator and switch
  11. IL WTB: 00-01 or Pathfinder Throttle Body
  12. NY 99-01 MAXIMA CATTMAN Y PIPE CALI SPEC COMPLETE STAINLESS STEEL-$225
  13. GA WTB Tan Leather Seats for local P.U
  14. PA WTB: Drivers Side Fog Light Bolt Cover
  15. TN Chrome R34 headlights with 5000K bulbs.
  16. FL MAF and rear coils
  17. MA FS: JDM/OEM Cefiro Aluminum Door Sills (Indiglo Blue)
  18. IL FS: Projector Headlights 95-99. Chicago, IL
  19. CA FS: VQ30DE for $200 No Need For It Anymore
  20. CA GI: 97-99 fogs
  21. CA WTB-97-99 AE clearance lights, (homemade)
  22. ND FS: SS Brake Lines $75 shipped ES Lower Control Arm Bushings $30 shipped
  23. NM Barely used Injen CAI for 95-97 Maxima
  24. CA FS JWT ECU w/ extended rev
  25. CAN-Other Testing waters : Anyone want a VLSD RS5F50V 5SP M/T from Canada
  26. NE FS-Door speaker amps/mounts
  27. CA 99 ecu
  28. MA FS: Q45 Woodgrain Steering Wheel (97-99 OEM SE Wheel - Direct Replacement)
  29. NJ WTB: A PILLAR GUAGE POD
  30. GA WTB Black carpet, not gray
  31. GA WTB Eibachs
  32. TX WTB: 97-99 Maxima Power Antenna Motor & Washer Motor
  33. KY F/S mafs starter headlights key fobs a few other things
  34. NY looking for some 18.....
  35. NY 4th gen rear driver door glass and corner window
  36. NY MINT Condition Heated seat switches
  37. NY Box of misc parts.. check it out
  38. MA All Mods for Sale LOOK!!!
  39. UT a few oem 4th gen parts
  40. CT F/S 97 5 speed ECU, se guage cluster
  41. NY FS: HID Bulbs with ballast
  42. NY F/S: Maxima CF MEVI replacement cover
  43. NJ Starterrr F/S
  44. CAN-Toronto FS: Lots of stock and aftermarket goodies
  45. FL FS Strut mounts
  46. CT Anniversary edition Shift knob Stillen Lip Sub box Gauges Lets GET EM SOLD!!!!
  47. NY transmission pan gasket PT#31397-80X01
  48. NY TURBO KITT !!!! 4TH GEN
  49. FL FS Test pipe and Cat
  50. WI 00VI For Sale - Bolt Up - Everything Included!
  51. NY 96 MAXIMA SE 5SPD WHITE/BLACK MUDFLAPS FIDANZA FOGS YPIPE RIMS BOSE SWAY BAR OPTIMA
  52. NJ FS: Random parts
  53. MA 1997 Nissan Maxima OES Genuine Idle Control Valve Idle Control Valve
  54. MA 98-99 Injen CAI for sale and aluminum grille!!!
  55. NJ agx, wheels,trunk,tires, taillights
  56. WA fs: Factory Bose headunit (works excellent)
  57. TN :::Megan Racing Products:::
  58. CA fs: 95-97 Climate control unit; oovi; misc
  59. NJ WTB: swirl control valve control solenoid
  60. CAN-Other WTB: lightweight pulley
  61. WA WTB: 1997-1999 Rear Stillen Pieces
  62. WA WTB: 1997-1999 Rear Stillen Pieces
  63. PA wtb 3.5 intake manifold elbow with pathfinder thottle body and and cable bracket
  64. MD Gauging Interest -Retros for Sale
  65. SC F/S 95-96 rear 02 sensor
  66. FL Progress RSB
  67. CA WTB: WEST COAST, OEM Air Box ASAP
  68. MA Thule 246 fit kit
  69. MA 4th Gen - OEM tail lights
  70. NC Budget Test Pipe with O2 bung, UR UDP
  71. PA FS: Z32 30mm BBK Setup
  72. PA FS: HID Retros
  73. CT License plate bracket/harness
  74. KY Wtb: Multiple things, Headers, y-pipe, Pathfinder throttle body, etc
  75. NY wtb: s/c kit asap
  76. MD FT- Monroe Sturts + Custom Enterprise springs
  77. MO WTB - O2 sensor
  78. IL FallenOne's For Sale Thread Updated 3/19/11
  79. RI WTB: Mudflaps
  80. VA MD NC Stillen Rear Swar Bar, Stillen Lip kit, Unothodox UDP
  81. SC FS/05 maxima injector rail+ injectors+clips
  82. PA WTB MAP Sensor for my 97 SE
  83. RI GI: Maxspeed Lowering Springs
  84. WI FS: Set of all 6 ignition coils
  85. CA FS: NEW Rear beam link Delrin/Aluminum bushings
  86. MN WTB: 1999 I30 Coilovers
  87. NY fs good passenger side axle
  88. NY fs VQ30de
  89. NY fs working 4th gen Bose system
  90. NY WTB Drivers side spindle, with ABS
  91. PA Automatic tranny for sale
  92. PA WTB: 98 Tan Steering wheel
  93. MA WTB: B-Pipe w/ O2 Hole
  94. GA WTB Eibachs
  95. NJ 2 BRAND NEW Denso oxygen sensors 234-3098
  96. CT Parts
  97. MN FS: 6 disc pathfinder headunit, rpm switch, iacv adaper and more!
  98. MD WTB or WTT R34 headlights for OEM 97-99
  99. NJ F/S 00VI W/O VIAS
  100. CAN-Toronto WTB: NEW front rotors and pads
  101. IL WTB 97-99 Fog Driver side/rear antenna
  102. TN WTB:98-99 white face cluster or SEL cluster
  103. CA 97' 5-speed ECU
  104. MN WTB: Front Strut Mount
  105. PA BUSHINGS AND END LINKS
  106. PA FS: BLK leather headrests/S.Techs
  107. PA WTB: Coilovers
  108. PA 95-99 fog lights
  109. MO ECU's
  110. NY fs 4th gen coil packs
  111. OH OH: F/S 4 OEM Bulbs for Climate Control
  112. NY fs mafs
  113. NY WTB Fog Lights 97-99
  114. ND FS:95-03 ES Motor Mounts Pressed Into Stock Brackets $200 Shipped
  115. CA FS/FT: 95-96 fog lights, brackets, fog stalk and relay!
  116. NY Warp speed y pipe
  117. NY fs 95/96 air bag controller
  118. CA WTB Progress Springs and rear 95-96 Stillen Body Kit pieces
  119. WA wtb: 99 i30 outter tails and center garnish
  120. MD WTB 96-98 manual heater control
  121. WA WTB: 95-96 Driver side fog light
  122. PA Wanted-Fr R&L Grey carpets & Fog Lights for 96
  123. MD FS: black 1pc cefiro's
  124. NY F/S: BNIB 4th gen front Oxygen Sensor
  125. FL WTB all 4 mudflaps for 4th gen
  126. FL WTB 15mm spacers
  127. TX Grill,97-99 fog brackets,Silverstar Ultra's,gauge pod
  128. MD F/S 2 Automatic Climate control Modules 30$
  129. WA wtb: Mudlflaps for 97 i30. (all 4)
  130. GA 00VI, Bose speakers, etc.
  131. PA will trade full swap for jwt ecu
  132. IL Ebay find: STILLEN RSTB
  133. CA WTB: Ignition Coil
  134. NY WTB: Aftermarket y-pipe
  135. FL 00vi anyone =]] for sale SOFL
  136. CA FS: Delrin/Aluminum Control Arm Front bushings NEW!
  137. NY My Maxima For Sale Upstate NY. Outside of Binghamton
  138. VA WTB: looking for lowering springs....
  139. NC WTB Stock Infiniti BBS wheels
  140. FL Injen Intake w/ Heat Shield
  141. WI 99 se cluster
  142. RI Black Leather Door Inserts
  143. DE WTB: Stock Muffler & Underbody Guard
  144. CA FS: 99 Auto ECU
  145. CA FS: BNIB GP Thunder Headlight Bulbs
  146. CA FS: A32 Stealthy Carpeted Box For a 12"
  147. NC FS: Quaife'd 5spd
  148. MD FS: Head set gasket, Blk Interior trim pieces, and Clear bumper light set
  149. NY fs 4th gen automatic sunroof
  150. NY fs gas filler fume return
  151. NY fs fresh 96 gle part out
  152. CT F/s Various parts
  153. VA FS:option racing springs, blk headrest, blk steering wheel,misc stuff pics inside.
  154. NC WTB: Side skirts, arm rest, fender
  155. MO 4th gen test pipe
  156. NJ WTB. EMANAGE ULTIMATE.
  157. PA FS: Cefiro's
  158. GA FS: New Set of Rear Tokico Blues
  159. FL FS Maxima Articles Motortrend, Nissan, C&D
  160. MN wtb: cat back exhaust
  161. NY WTB: Stillen front lip
  162. NY fs 99 steering column with key
  163. NJ FS: 95-99 Mishimoto Radiators/rad hoses and VQ35 racing thermostats
  164. NJ WTB: Y PIPE
  165. TN FS: Complete Set of 95-96 Fogs
  166. FL WTB: Stock Rear Speaker Grills
  167. TN FS: BNIB Rear Valve Cover Gasket
  168. FL fs 98 max r tail lamp
  169. FL Gutted Motor Mounts for ES Bushings
  170. NV WTB: Stock suspension pieces
  171. VA F/S JWT 5spd ECU $400 shipped
  172. GA IACV adapter plate
  173. NY Brand New Energy Suspension control arm bushing. $25
  174. TN vq30de breakdown
  175. NH wtb: Almuminum Radiator
  176. ND WTB: Rear Shocks
  177. CAN-Other Magnaflow Catalytic Converter
  178. CAN-Other INJEN Cold Air Intake 95-97 Nissan Maxima + free Oil Filter+ Air Filter Cleaner
  179. MD FS: motostorm FSTB
  180. DE For Sale- XSpower Headers
  181. FL Tokico rear struts for sale
  182. KY WTB ss clutch line
  183. SC R34 headlights with duel fx35 projectos with high beam hid 8000k dr2 bulb
  184. NJ WTB IACV Adapter plate
  185. SC apexi turbo timer for sale $45 shipped
  186. MN GB TRUAX SFC LIMITED PRODUCTION! ENDS MARCH 5TH
  187. NY WTB 4TH GEN MUDFLAPS
  188. NJ WTB: MAP/BOOST SENSOR SOLENOID
  189. CT Stock 97 5spd ECU
  190. SC clutch pedal and clutch master cylinder oem almost new
  191. SC WTB: 4th Gen y pipe
  192. NY 95/96 Inner Tail Lights $20
  193. NY WTB Side Marker Lamp Socket W/ Harness
  194. SC Z32 aluminum front 300zx calipers 26mm with ss lines
  195. LA FS Interior,Exterior,Suspension, Audio,Tuning
  196. MN Bomz Racing ram air intake- $12
  197. NY FREE SE struts and suspension components
  198. PA 4th gen aftermarket part-out
  199. MA air ride suspension
  200. NJ FS: Cargo Net - MINT
  201. NY 95-96 MAXIMA FOG LAMP STALK AND 97-99 MAXIMA FOG LAMP STALK-$35 SHIPPED EACH
  202. FL Miscellaneous 4th Gen Parts
  203. CO WTB Keyless entry FOB 99
  204. TX Multiple items FS
  205. NY WTB: 4thgen Triple Guage Pod
  206. ND FS: 95-97 SE Cluster $60 shipped
  207. IL WTB: 00-01VI NWP Phenolic Spacer Set
  208. TN Used OEM Maxima Parts
  209. VA FS: Wilwood Calipers, pads and mounting brackets
  210. MD FS: Black Steering Wheel
  211. SC Airomotive rising rate FPR and a apexi turbo timer for sale
  212. SC FX35 projectors for sale ..used Hid kit 8000k very little use.
  213. SC Z32 aluminum front 300zx calipers 26mm with ss lines
  214. NJ WTB - Black R34 headlights for a retro ..
  215. CA FS: Dash Trim, Intake adapter, Dome Lights
  216. NY 98 Maxima Digital Climate Control Unit
  217. NY 4th Gen Maxima/i30 OEM key fobs
  218. NY Radiator overflow tank OEM
  219. NY F/S Radiator fan motors
  220. PA FS: JWT ECU, LED Tails, HID Retros, BBK, G35 rims
  221. PA FS: 4th Gen Parts - Q45 brakes, bushings, i30 mirror, Etc.
  222. MD 4th gen headlights
  223. OH WTB - Stock or aftermarket exhaust for my '97 SE
  224. NY F/S: 4th gen dk green fuel door
  225. IL FS: J30 Projector Headlights
  226. NY F/S: DEK rear valve cover w/ new gasket for 00vi swap
  227. NY WTB: Short Throw Shifter (B&M, Stillen, etc.)
  228. CT FS 95-96 Stillen Lip
  229. NJ WTB: Valve Vacuum Assembly
  230. CA FS: Stock Intake System
  231. CA FS: 99 I30 Limited Headlights and Corners
  232. NJ Various engine parts vq30de
  233. NJ Looking for R34 headlight mounting brackets and bulbs
  234. CT 97-99 Cattman b-pipe & rezzy w/oem muffler and tip
  235. NJ Looking to buy HID retro fitted headlights
  236. MD Kyb Shocks & Struts *Brand New*
  237. CA Ft: My VIP JIC FLT-TAR Coilovers for your springs/struts
  238. NC FS:2xUIM,fuel rail, timing cover and more plus FREE 3.0VQ
  239. NY fs 4th gen stock struts
  240. NE FS- 4th Gen OEM SE Headunit
  241. NY fs fog light brackets 97-99
  242. RI WTB: cat back exhaust.
  243. CA WTB: Tein S-Tech springs.
  244. NY WTB: 4th gen headlights
  245. VA FS: 97 Fogs with brackets
  246. NJ wtb one rear coil
  247. MD 1pc Black R34 style headlamps (NEW)
  248. TX FS: Custom 4th Gen Console with Alpine Touchscreen
  249. GA Engine Parts - Coil Packs, Injectors, etc
  250. MD WTB- 98 Stillen front lip
