Removing scoop and interior AC intake
I searched around and didn't find any conclusive answers.
The scoop goes down and splits, one directs air to where the airbox used to be, and probably gives a little help to the cone filter (inconclusive evidence, I know).
But, the other part goes under the battery to the air conditioning system
I ask this because I degreased my engine the other day and I think I may have either sprayed some close to that area or something, because you can smell the degreaser when you turn the climate control fan on. It's slowly going away but I was considering removing the scoop anyway. If I do so, do I just leave that hole open or do I put some sort of filter on it? Thanks for the help guys.
???I ask this because I degreased my engine the other day and I think I may have either sprayed some close to that area or something, because you can smell the degreaser when you turn the climate control fan on. It's slowly going away but I was considering removing the scoop anyway. If I do so, do I just leave that hole open or do I put some sort of filter on it? Thanks for the help guys.
The tube going underneath the battery has nothing to do with the cabin ventilation system. It is actually a tube to the resonator box, which is supposed to keep the intake system quiet i think.
The intake for your AC system is located near your windshield beneath the wipers.
That explains the smell then.
As you can see here
http://maxima.cardomain.com/member_p...=221773&page=2
The firewall of my car was hella dirty and when I used the degreaser a lot of it went to that area.
Thanks guys. Once again I hope this helps someone to search and find the answers they may have.
As you can see here
Mar 12, 2020 12:06 AM
