Is my brake reservoir switch wire is short?
The resistance between the 2 wires of the brake oil reservoir switch is 0 ohms. I am not sure if it is normal or the wire is short some where. How can I fix this short? One wire is yellow and the other is black. Because of this my brake warning light stay on all the time.
Re: Is my brake reservoir switch wire is short?
mipinc
How are you measuring the resistance to get 0 ohms - with the connector disconnected?
Check the harness first: disconnect the connector, get a couple of paper clips and measure the resistance across the two wires at the connector. 0 ohms and your wiring is shorted. Infinite resistance and your switch is probably stuck.
Re: Re: Is my brake reservoir switch wire is short?
Originally posted by pocketrocket
mipinc
mipinc
Re: Re: Re: Is my brake reservoir switch wire is short?
One goes to any ground (body earth would do fine).
The other is spliced to the circuit that goes from the meter to the e-brake switch.
I have no idea where your short is, one thing you could do is rewire the circuits ... if you're up for it that is
You sure your e-brake switch is not stuck in the up position (grounded)? If it is, you'll end up measuring close to 0 ohms across the two wires at the brake oil switch connector. You've probably done this already but disconnect the connector from the e-brake switch and see if it goes away.
Re: Re: Re: Re: Is my brake reservoir switch wire is short?
The Frye
Sep 2, 2021 11:03 AM
