Installed Berk Intake (Sweet!) but now my sunroof doesn't work....???
Old Jul 18, 2002 | 07:48 PM
JohnnyV'02SE's Avatar
Ok, I got my Berk intake today and installed it according to the directions they provide. I disconnected the battery just like they say to. Well, I got it installed just fine and I love it! Definitely a SOTP HP increase. Car pulls a lot harder above 3,000 RPM's now.
Now, for the crappy part. My sunroof no longer works. It just quit working. The sliding switch doesn't do anything. I can however open it with the little tilt switch. I can open it all the way with that switch (is this strange?). I never tried it before so I don't know if it used to do it or not. Why would this happen???
-Johnny V.
Old Jul 18, 2002 | 07:55 PM
xChungHsienx's Avatar
Re: Installed Berk Intake (Sweet!) but now my sunroof doesn't work....???
-Johnny V.
yea this happens when you disconnect the battery. You have to reset the sunroof by holding down the tilt for a couple seconds. It should work after that. If i'm wrong about the resetting try a search and you'll see many ppl had the same thing happen, but i'm pretty sure thats how to reset it.
Old Jul 18, 2002 | 07:59 PM
DJSCIASCIA's Avatar
Same thing happend to me....open it with the switch on the right that makes it open slowly, then close it using the same switch, once its closed press it again so that the roof tilts up and then have the roof close by hitting the same switch to close...after that try the slide switch and see if it works...mine did after i did that...
I think the roof goes haywire when u disconnect the battery.
Old Jul 18, 2002 | 08:36 PM
Virus's Avatar
How does the intake sound? Deep?
Old Jul 18, 2002 | 08:43 PM
Maximam's Avatar
You felt immediate gains?? My Max didn't seem to get any gains till like a day later.
Old Jul 18, 2002 | 09:12 PM
[maxi-overdose]'s Avatar
ecu needs a few day to adjust it....I dun feel it until a week later..well, I didnt floor it untill a week later
virus : berk intake sounds like stock when idel..but once WOT, it has a deep growl...much deeper than the stock.
Old Jul 18, 2002 | 09:13 PM
NYC2SD's Avatar
Does anyone know why they make this sunroof reset feature? The same thing happened to me when I picked my car up from the dealer. I was fuming until I read the manual.
Old Jul 18, 2002 | 09:36 PM
So it's in the manual??? Why the hell would they do this???
On the sound of the intake...it sounds awesome at WOT. At idle, just as quiet as before. I think this intake should put me ahead of my Mom's CL-S. It really seems to pull harder. It'll be really nice if the ECU learns as it goes and I pick up more hp than I already have.
-Johnny V.
Old Jul 19, 2002 | 03:07 AM
Virus's Avatar
What's it sound like under normal driving? A little louder, same or considerably louder?
Old Jul 19, 2002 | 05:38 AM
Colonel's Avatar
Old Fuddy Duddy
So it's in the manual??? Why the hell would they do this???...
It not just Nissan. I have a 2002 with the whole 1 touch system and if you turn it off (ignition) while its moving or unplug the battery it goes nuts. Knowing about the reset on this board helped me figure it out. Has to do with the electronics vs manual switches perhaps?
Old Jul 19, 2002 | 07:18 AM
sleepur's Avatar
i got the berk on my 01 se, above 3000, it is NICE, deeper growl, where you usually hear the engine, you can hear that baby sucking up the air. But there is an audible whistle below 3g's, which is sometiems annoying if you have the windows down. Solution is to just drive fast all the time.
I hear people complaining about MAF going, I assume the car wont run, but what exactly happens when it goes bad, engine stop? Overheat?
thanks in advance for info
b
BobMax
Aug 21, 2015 07:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
Maxboy23
Aug 11, 2015 11:59 AM
