Popping noinse in turns after replacing manual tranny bearings
I recently had the dealer replace my bearings due to an oil leak at the axle. Now after the work was done, I get a pop or a ping when I go around a corner and bring the steering wheel back to center. I can feel it in the wheel and hear it. It doesn't happen all the time, and only when moving.
I pulled the strut out and checked the bearing and re-wrapped the coil with insulation and it is still there.
Does anyone have any idea what this popping noise could be?
Re: Popping noinse in turns after replacing manual tranny bearings
Re: Re: Popping noinse in turns after replacing manual tranny bearings
Originally posted by njmaxseltd
Only when moving lends me to think you've got a CV joint gone bad.
I get the same damn thing!!! I've had it since I got my car (~5000 miles ago). It's definitely somewhere between a "pop" and a "ping" and happens once the steering wheels has just about returned to the center position.
I had a few CV joints go on my old Maxima and this is not the same noise.
It almost sounds like its coming from the steering column or something.
njmaxseltd... you can listen to it at the NJ meet on the 4th
I would love to know what this is.
Like I said it's always been on my car, so I didn't even notice until my brother went for a ride and asked about it. At first I thought it was the wheel catching on my key (dangling off ignition) but this clearly was not it.
Maybe it has something to do with the steering rack... but in any case if it appeared after you had the dealer work on your car you should get them to at least diagnose it... if they messed up you shouldn't have to pay for it.
Their wonderful suggestion was to drive it around and maybe it will get worse to where it will be easier to diagnose. But believe me, I will definitely be taking the car back to them. I just wanted to see if anyone had a similar problem and maybe knows what the cause is.
Did njmaxseltd get a chance to hear it at the meet you referenced above?
Try this -
Spray A LOT of WD-40 on your spring coils. Get it up in there really good and then take your car for a ride. If the noise is gone, you've found the source.
Try this -
Try this -
I rewrapped the insulation around the bottom of the coil and checked the strut bearing. The noise is still there. The only thing that I noticed was that that thin red gasket or noise insulator that goes between the strut mount and the housing had ~3mm crack halfway between two of the bolt holes.
Also, I did not replace the strut bearing, it was still greased and felt smooth, but maybe I should have.
Any other suggestions?
Rage Maximus
Sep 3, 2015 12:26 PM
carlosvq30
Aug 17, 2015 11:32 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
