needing some guidance!!!
Old Aug 1, 2002 | 08:14 PM
SeMax21's Avatar
first of all this is my very first post so it might be long. i just bought a 92 ve 5 speed and man did this thing just run awesome but then it would misfire. I think it was misfiring, because i would hammer it then it would kick back lose power, i would take foot off accelerator then it would come back. this would only happen once in awhile. Well i thought it was the plugs, so i changed them to the stock ngk plugs man were they $$$. So i notice i get some crisper acceleration then i decide why not put fuel injector cleaner in so i did. well it lost a lot of power for about 2 days so now it's burned off. i use 93 octane gas and now i don't have that power i once started with. it takes forever to accelerate now and i'm starting to worry. im mechanically retarded but i have a family freind that can do the work. but i need to know if fuel injectors would cause a loss in acceleration, and cause your car to jerk a little. I mean i almost lost to a taurus on the highway please help me i need to represent the maximas better than this. I don't beat on the car like a typical teenage ricer, but now and then it would be nice to stomp a civic hatch with a swap. i'm afraid to open my car up because it uses some gas and hesitates. oh yeh it's really hot here but this was tonight and it's around 65, a cool night. so i don't know if the typical max sux in heat thing is what i'm going through. all i know is there's a lot of smart owners on here that might help me. oh yeh please don't tell me to search because right now i don't know what to search for. peace jerad.
Old Aug 1, 2002 | 08:25 PM
poorcollegeboy's Avatar
Re: needing some guidance!!!
try checking your coils
Old Aug 1, 2002 | 08:29 PM
SeMax21's Avatar
i don't know what they are sorry man no knowlege of cars trying to learn here. are they ignition coils or something like that? anyways i'll search for that thanx for replying man, anyoneelse feel free. peace
Old Aug 1, 2002 | 08:52 PM
the coils are located right above your spark plugs. you've got three in the front and three in the back. they're all roundish looking at them from the top. the front three has one screw holding them in. the back three as two screws. just unscrew them, pull them them out, and see if they're cracked or discolored.
Old Aug 2, 2002 | 04:51 AM
SeMax21's Avatar
alright i'll check that in a little bit thanx for the help. peace
Old Aug 2, 2002 | 07:20 AM
SeMax21's Avatar
ok i have one question. when i changed the plgus in the back 3 and disconected the wires to unscrew the two screws would it mess up my car if i put the coils in out of order? I might have mixed up two would this make a difference because i'm thinking of swapping the two to see if it will? will it hurt anything if i do this? thanx peace
Old Aug 2, 2002 | 09:03 AM
swapping coils is ok. just make sure you don't swap the connections to it.
Old Aug 2, 2002 | 09:32 AM
SeMax21's Avatar
alright the coils look ok no cracks or discoloration. i cleaned the throttle body today man am i happy i finally did work myself. seemed to help a little but the acceleration still isn't what it used to be. what about the injectors or something else. thanx to those who replied. peace
Old Aug 2, 2002 | 10:21 AM
Matt93SE's Avatar
STFU n00b!
what kind of injector cleaner did you use? the gunk you dump in the gas tank on a fill-up?
that could be your problem. those cleaners contain HARSH chemicals that can actually eat the insides of the fuel injectors. either that or they can break loose gunk in the fuel lines and clog the injectors.
they could also do the same to the fuel filter.
try changing your fuel filter and see what happens there. (it's the metal can on the firewall with two big rubber hoses on it. be careful when removing it cause he fuel is under pressure- it'll spray a bit when you pull the line off. I just hold a rag over it, but others relieve the pressure before opening the system.
Old Aug 2, 2002 | 10:53 AM
blackandwhite's Avatar
To them I'm like an idol
Sounds a lot like my Mass Air Flow Sensor problem. It started as an occasional miss, and/or bog down. Then it got worse, it would lock into fail safe mode (would go above 2250 rpm). I got a new MAF sensor and that fixed it.
Have yours checked out. If it's bad, I have an extra one that I bought to replace mine when I could wait on shipping for another one I had already bought.
Matt93SE
May 24, 2019 02:58 PM
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
MikesChevelle
Aug 9, 2015 11:50 AM
