Max's with 17" or higher rims
No... just keep the tire size about right 17" 235/45-17 18"s 235/40-18 or 19" 235/35-19... you can do variations I run 245/40s on my 18"s and soon to run 245/35s on my 19"s
just search all your questions will be answered
Re: Max's with 17" or higher rims
Originally posted by xsp00kyx
did you guys have to adjust anything to the car to get 17's or 18's? like raise it or something? will turnign be a problem? thanks for the info
It depends on how wide the rim is and the offset. If a rim is 10" wide, you will have problems, even in the back. I think stay with 9" as the largest and still a +40 offset and you should be fine.
-Cyrus
-Cyrus
The gap won't be thinner if you get the right size tire. Because the sidewalls of the tire are thinner, but the wheel is larger, and the overall diameter should stay the same. The gap won't change. If you do go for bigger wheels, please do the nation a favor and lower it. Stock unlowered I can handle, but 18's and unlowered? Blech!
Carnal_c30 you have a PM
-ChRi§
hehe thanks but one more question, say you do get like 18" or 19" even 17", will the car look like it was dropped? since the gap will be thinner?
-Cyrus
Originally posted by Ramse
If you get 235/45 17" tires, it will look exactly like the stock 15's you got on now. The only difference is the rim diameter is larger and the sidewall of the tire is less (it all evens out).
Originally posted by Vyrus
It will looks like you have more gap. It will honestly look aweful.
-Cyrus
-Cyrus
I do think it would look better without the gap. for those wondering, they are 17's with 235/45/17s
Originally posted by erty67
I wouldn't say my car looks aweful with the gap.
Kevin
Ant
0m3nc0w
Sep 11, 2015 05:21 PM
