Is the STS supposed to be is far forward?, it touches the front of the shift cutout.
I just installed my short throw shifter, it seems to work fine but in first, third and fifth it touches the front of the shift cutout. In second, fourth and reverse it is in the middle of the shift area. Is this right? It feels wrong but maybe I will get used to it. It definatly does not go the other way, I tried turning it around and it was even farther forward.
BTW - it is the pacesetter STS from Custommaxima.
not really. I should go take some pics of mine in every gear for you to see. When it's in 4th it looks like it's in neutral, but when it's in 1-3-5 it shouldn't be touching the top.
Re: Is the STS supposed to be is far forward?, it touches the front of the shift cutout.
I had a problem with fitment when it was first installed. The shifter was cocked to the right. I dropped the entire shifter assembly like you mentioned in your other STS thread. I traced the problem to the rear bracket, the same one that you have the red arrows pointing to in the pic you posted.
When I installed the rear bracket I wasn't paying close attention and fastened it down crooked. I went back and straightened it and the shifter worked fine. Try moving that rear bracket around to see if it helps.
Re: Re: Is the STS supposed to be is far forward?, it touches the front of the shift cutout.
Originally posted by speedtrip
I purchased a pacesetter short throw shifter from custommaxima 3-4 weeks ago. My sts is about a 1/4" to 3/8" away from the front cutout.
My STS is very close to the cutout, but does not touch even under hard, sudden acceleration when the shifter 'leans' forward a bit. It is close, I've got to imagine that you could do some manuevering to get it a bit further away. Maybe throw a washer or two between the frame and the bolt closest to the front of the car on the shifter housing so the shifter would be tilted backwards slightly? That's just a random thought trying to picture the mechanism in my head.
The pacesetter does make the shifter look like it's in Neutral when in 2nd and 4th. I like it better when the shifter is far back, I don't know why...but the short throws are worth the trade off.
I think the 2k+ Mustang shifters are bad@ss, the bent rod causes the shifter to be set at an angle, and the shift **** is curved too. Looks like a cobra snake! Wish Nissan made the minima with that type of shifter.
Michael, your shifter looks very nice, but totally different from the stangs. Here is the internals of the stang's shifter assembly:
And here is the shifter itself:
The shifter color is ugly but I love the design. I wonder how the throws are on that thing. How much custom work do you guys think it would take to get that thing on a Max? I wonder if the shifter's placing is directly where the max's is so it could be a direct fit or not...
Anachron, is your shifter noisier now? It seems my STS is stiffer AND noisier (more mechanical rubbing of the linkages sound) then stock maxima shifters
Could we possibly heat up the pacesetter rod and bend it a little more so it ended up closer to the center?
delerium75
Aug 19, 2015 11:08 AM
