300zx brake conversion
Old Aug 7, 2002 | 05:28 PM
avusblue92se's Avatar
i have searched this topic numerous times, but am still vague on the correct procedure. the directions on maximadriver.com say to mill 3mm off the RADIUS; and the people here on the org. have said 3mm of the CIRCUMFERANCE. i want to do this conversion asap because i have all of the parts laying around my house. so all of you that have done this procedure, which is correct? thanx for your time,
Justin
Old Aug 7, 2002 | 05:37 PM
maxstyle98's Avatar
Re: 300zx brake conversion
Justin
I am curious as well. Radius or diameter, I doubt it's circumfrence that wouldn't be a typical measurement for this type of application. If it is radius then you will need to take 6mm off the dia.
What is the dia. of the 300zx rotor anyway?
Old Aug 7, 2002 | 06:07 PM
mingo's Avatar
Justin
it's the radius... i think i only shaved off 2mm off the radious..
Old Aug 7, 2002 | 07:41 PM
see5's Avatar
I have owned one of those 92 300ZX TTs and the brakes are the biggest downfall. They go but do not stop.
I would not do it.
Old Aug 7, 2002 | 07:58 PM
mingo's Avatar
I would not do it.
maxima brakes are worse, mine failed on me twice.. i guess it all depends on what type of pad, fluids and lines you run too.. i have poterfields r4s, powerslot rotors, goodridge stainless steel lines, motul600 stoppin' my car.
Old Aug 7, 2002 | 09:56 PM
Max Power X's Avatar
I would not do it.
Do you think 2k2 Max brakes are better than the 300ZX TT brakes?
Old Aug 7, 2002 | 10:37 PM
mingo's Avatar
nope..
i have the 91 300zx twin turbo brake set up, the rotors are slightly thicker on these than the other z's that translates to, better heat dissipation (sp?) but higher rotational mass meaning more unsprung weight. nonetheless i still would recomend em'. i plan to eventually upgrade to even bigger brakes, but for the time being i'm sticking with the z's (money issue)
Old Aug 8, 2002 | 08:41 AM
Lordrandall's Avatar
I would not do it.
A TT is much heavier than a Maxima. The 300ZX front calipers an brakes are a great upgrade.
Old Aug 8, 2002 | 08:52 AM
redmaxpa007's Avatar
i SeE what you did therE
they are my nex mod... i am going to do the rears also.. i just gotts figure out how to "redo" the ebrake.. hmmm i have an auto.. i don't need one..
Old Aug 8, 2002 | 09:10 AM
Handbrakes are fun
Old Aug 8, 2002 | 03:01 PM
see5's Avatar
I think the 02 Max brakes are better than my 92 TTs, as there have been 10 years of improvements and let's get realistic: the brakes on the new Maximas are excellent and the 300 TT guys were quick to upgrade as I did.
The weight of the TT was a bit more but it had lots more tire.
Old Aug 8, 2002 | 08:49 PM
How many pistons do 2k2 calipers have, probably not 4 right? If not I'd get the 300ZX TT calipers and upgrade the rotors, pads and such, like this setup:
http://forums.maxima.org/showthread....caliper+piston
Old Aug 9, 2002 | 02:47 AM
mingo's Avatar
i got the 91 calipers instead of the newest z calipers because they were aluminum. (lighter)
Old Aug 9, 2002 | 04:09 AM
do you know where i can find some?
Old Aug 9, 2002 | 07:10 AM
Axel's Avatar
Re: Re: 300zx brake conversion
Same here, only 2 mm off the radius...
Old Aug 9, 2002 | 07:13 AM
mingo's Avatar
autogator... i mite be getting rid of mine.
Old Aug 9, 2002 | 01:21 PM
How much?
Old Aug 9, 2002 | 02:01 PM
mingo's Avatar
How much?
for u??? hrmm... fai dollah i dunno yet..
Old Aug 9, 2002 | 02:10 PM
haha, thanks bud. Let me know please.
Brakes are next on my list.
Old Aug 9, 2002 | 02:13 PM
Chebosto's Avatar
RIceD OuT moDErAtor
Benefits of Z brake conversion:
Higher heat capacity, and 4 pistons.
BUT
if you have x drilled maxima rotors with Hawk or Porterfield brake pads with SS lines. i guarantee you it will stop just as well.
if you're gonna race on the track, then i HIGHLY recommend hawk or porterfield RACE pads to prevent fade.
Z brakes are cool but wont fit certain rims. PITA>
Old Aug 9, 2002 | 02:29 PM
Think they will fit my RX7 rims Ches?
Old Aug 9, 2002 | 06:23 PM
mingo's Avatar
well when i go down south i'll let u see if the rims would fit on my car, then u'll kno... and dont' worry i won't drive away with em'.. i don't like the "i have 3 18" wheels + one stolen rx-7 rim" look.
Old Aug 10, 2002 | 06:27 PM
How much?
HEY!!!
stop trying to bet in on buying something i am try to get first!!
Old Aug 10, 2002 | 10:49 PM
Sounds like a plan! Hopefully the 4th gen and 3rd gen caliper mounts are in the same place......
Old Aug 11, 2002 | 12:41 AM
mingo's Avatar
very similar.. if not the same.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
