How do I fit an Optima?...
Old Aug 8, 2002 | 07:53 AM
Vyrus's Avatar
Just curious is all that's required I chop the top off the battery box? So the terminals reach fine and I don't have to remove the top completely? Also which model Red Top should I be looking at for my 4th Gen?
Thanks,
-Cyrus
Old Aug 8, 2002 | 07:56 AM
Sprint's Avatar
get a 1 inch thick plexi glass and put it over hte top of the battery.. then it will work.. i would get the yellow top.. even though the Red Top is a bit better.. you can drain the yellow top fully and then recharge it.. but i would do that because i have a sound system.. you might need more crankign power so you get the red top..
Old Aug 8, 2002 | 07:59 AM
Vyrus's Avatar
Couldn't I put the plexi-glass underneath? And it will still fit in the battery box? I would rather cut the box though, would that work okay?
Thanks,
-Cyrus
Old Aug 8, 2002 | 08:00 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
4th gens that don't need the Yellow top should get an Orange top so that the positive and negative poles facilitate easy installation.
Old Aug 8, 2002 | 08:02 AM
Sprint's Avatar
Thanks,
-Cyrus
technically you could.. but thats going to be a piece of plexi glass the same legth and with of the battery.. where as you could just get a piece the same width and legth of the tie down.. its up to you..
Old Aug 8, 2002 | 08:03 AM
Vyrus's Avatar
Okay I see how it fits and I think I'm just going to cut off the top of the box, and lower the tie-down. Thanks Sprinty.
-Cyrus
Old Aug 8, 2002 | 08:41 AM
Wizeguy's Avatar
The problem with the fitment is that the optima batteries are shorter then the stock unit. The tie downs aren't threaded down far enough to clamp down on the shorter battery. I just put a few larger nuts on the tie downs to fill the space. Then tightened up the stock nuts. Works like a charm. Oh I also removed sides off the stock tie down bar to fit flat on the optima. Gotta love a hack saw.
&nbsp;&nbsp;-&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;- < - Standard nut now at threaded level.
&nbsp;&nbsp;=&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;= < - Larger nut to fill the space not threaded on
|&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& nbsp;|
|&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& nbsp;| < - Battery (pretty cool huh?
Old Aug 8, 2002 | 08:47 AM
ericdwong's Avatar
I answered this in the 4th gen FAQ, but I just took some scrap wood and put it underneath to "boost higher" the battery. The terminals fit fine.
Old Aug 8, 2002 | 08:52 AM
Lordrandall's Avatar
Eric, you should send your burn out video and some pics to SCC....
Old Aug 8, 2002 | 03:49 PM
metallic97gxe's Avatar
Master Will
I did not have to modify anythisng to get my Yellow top to fit....but then again I have 24KT gold Stinger terminals also....
Old Aug 8, 2002 | 05:27 PM
1MAX2NV's Avatar
Or you can just buy new J-hooks that has enough threads.
Old Aug 8, 2002 | 06:17 PM
ny96max's Avatar
or you can buy two "nuts" and slide them over the J-hooks(on top of the battery tie down bar) and build up the height for the securing nut(stock) hense making it tighter and leaving you enough thread to tighten down the battery!!
...then you have to buy a polished battery tie down from MAX8MYCASH
Ant
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
