? about Oil Change???
Old Aug 14, 2002 | 12:49 PM
95seMax's Avatar
i have a 95 maxima and the service book says my car should take 4 1/4 quarts of oil, but when i did an oil change and changed the filter , and added 4 quarts of oil in and checked it , its on the full point on the dip stick, i waited a few days and checked it again and its still full,
now the question i have is should i still add the other 1/4 of the quart in or should i leave it alone and leave it with 4 quarts , i heard its bad to overfill so i want to make sure
Old Aug 14, 2002 | 12:52 PM
iwannabmw's Avatar
Re: ? about Oil Change???
I'd leave it alone. Chances are that last 1/4 qt. wasn't drained. It's almost impossible to drain the entire system capacity. As long as the level indicates fine, it's no big deal. On the other side of things, an overfill of 1/4 isn't going to cause problems either.
Old Aug 14, 2002 | 12:59 PM
hokiemax's Avatar
I just buy 4 quarts of Mobil 1 for every oil change because it's easier to buy just 4 quarts, instead of getting 5 for the last 1/4 quart. You're not doing any harm to the engine, so dont worry about it.
Old Aug 14, 2002 | 01:33 PM
dedek's Avatar
As long when you check the dip stick shows full, you're fine..
In my case, when I drained the oil I waited for about 1 or 2 hours until the last drop. Then I needed to pour 4.25 quarts.
Old Aug 18, 2002 | 02:38 PM
NotNew!!NewSN!!'s Avatar
wanted to know if there is anything wrong with filling it with 5 quarts, we filled it up and then found out it required 4 and 5/8's. Should i rilly drain a lil bit, or am i fine. its 10w-3o mobil. i figure thats a good weight cuz im doin hella highway driving and its hot as heck.
Old Aug 18, 2002 | 03:17 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Overfilling the crankcase is bad.
Yank your filter off, then put it back on. Repeat as needed to get capacity back to correct level on dipstick.
Old Aug 18, 2002 | 05:43 PM
the thing is is that its going to the second bump(highest one) on the dipstick, is that where it should be?
JoshG
51
Sep 21, 2015 10:41 PM
f.matejaiii
Sep 21, 2015 12:09 PM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
