? about Oil Change???
i have a 95 maxima and the service book says my car should take 4 1/4 quarts of oil, but when i did an oil change and changed the filter , and added 4 quarts of oil in and checked it , its on the full point on the dip stick, i waited a few days and checked it again and its still full,
now the question i have is should i still add the other 1/4 of the quart in or should i leave it alone and leave it with 4 quarts , i heard its bad to overfill so i want to make sure
Re: ? about Oil Change???
As long when you check the dip stick shows full, you're fine..
In my case, when I drained the oil I waited for about 1 or 2 hours until the last drop. Then I needed to pour 4.25 quarts.
wanted to know if there is anything wrong with filling it with 5 quarts, we filled it up and then found out it required 4 and 5/8's. Should i rilly drain a lil bit, or am i fine. its 10w-3o mobil. i figure thats a good weight cuz im doin hella highway driving and its hot as heck.
Yank your filter off, then put it back on. Repeat as needed to get capacity back to correct level on dipstick.
Originally posted by bill99gxe
Overfilling the crankcase is bad.
JoshG
51
09-21-2015 10:41 PM
97_GXE
20
09-17-2015 08:12 PM
ag90fox
09-09-2015 12:22 PM
sdotcarter
09-02-2015 09:53 PM
