What is needed to supercharge a car?
Old Aug 21, 2002 | 11:01 PM
ionicmax's Avatar
Former Sponsor
Hi:
I'm exploring the possibility to offer an inexpensive alternative for supercharging the maxima.
I know that I would need the supercharger, a special plate to be able to mount it and have the belt run around it, and some piping to run from the air filter to supercharger then to the intake. What else do I need?
I would appreciate any feedback from people with knowledge!
Old Aug 22, 2002 | 02:54 AM
Sprint's Avatar
a kit from stillen
Old Aug 22, 2002 | 04:08 AM
redmaxpa007's Avatar
i SeE what you did therE
Originally posted by SprintMax
a kit from stillen
actually if you can get some one to scan the parts list for you that would help out greatly...
Old Aug 22, 2002 | 05:41 AM
Sprint's Avatar
its in the search.. it really is..
http://forums.maxima.org/showthread....t=supercharger
Old Aug 22, 2002 | 07:00 AM
clee130's Avatar
http://forums.maxima.org/showthread....s+supercharger
Originally posted by emax95
I just went way out of way for you and dug up a old email off of my old comuter from 6 months ago. This info was emailed to me by accident and is not supposed to be available to the public. In short you better thank me for this . This is really long and in depth so enjoy.
Bill of Materials
Packing Check-off Sheet
Stillen Super Charger 95-99 Nissan Maxima
P/N 407000
oAssembly person _________________________
oDate: _____/_____/_____
oSales Order # ____________________________
oSupercharger serial number:________________
o Instruction sheet with pictures and schematics
o STILLEN SUPERCHARGED Plaque 100505 Assembled
by__________________ Date ___________
Materials supplied:
(1) Air Filter Assembly Assembled
(1) Silicone Hose, Blue - Æ3 ½” air filter to
supercharger 407000-11
(1) Steel Insert-air filter to supercharger 407000-02
(2) Hose clamp, #56 407000-14
(1) Blow-off hose nipple 407000-61
(1) Air filter with holes drilled 407000-10
(1)Vortech Supercharger assembly. Assembled
(1) Supercharger 407000-01
(1) Supercharger adapter plate assembly 407000-07
(1) M12x50mm Flat head bolt 407000-74
(1) Idler pulley 407000-26 (2) M12x70mm Flat head
bolt 407000-36
(1) Supercharger drive belt 407000-29 (4) 3/8-16 x
4 ½ Flat head bolt 407000-37
(1) ½-20 x 1 ½ Hex head bolt 407000-72 (1) M12
Flat washer 407000-73
(1) Fitting, -4AN Male – 1/8NPT male 407000-56 (1)
3/8-24x1 Flat head bolt 407000-76
(1) Intake tube w/blow off mount, Æ2 ½” with STILLEN
decal 407000-03 Assembled by__________________ Date
___________
(1) Modified thermostat housing assembly. Assembled
(1) Modified thermostat housing 407000-05
(1) Thermostat housing gasket 407000-63
(1) Crankcase breather hose assembly Assembled
(1) 36” Æ5/8” ID Crank case breather hose 407000-15
(1) 90° Æ5/8” OD Plastic vent line adapter 407000-66
(1) 45° Æ5/8” OD Plastic vent to air filter 407000-65
(1) 2” Æ5/8” ID Crankcase breather hose NEED P/N
(1)Oil feed line, -4 S.S braided line 407000-25
Assembled by__________________ Date ___________
(4) Adel clamps, Æ5/16”, w/Æ1/4” bolt hole 407000-51
(1) Oil Tee adapter assembly 407000-56,57,58
(2) M6x1.0x30MM HHCS 407000-46
(2) Aluminum spacers, ƽ” OD x Æ ¼” ID x ½” Long
407000-17
(1) Blow off hose to air filter Assembled
(1) Æ1” ID x 20” Long 407000-62
(1) Fuel pump assembly Assembled
(1) FMU (Fuel Management Unit) – Comes from Vortec
assembled
(1) Bracket, Auxiliary fuel pump 407000-09
(2) Rubber Insulators – Fuel pump bracket 407000-67
(2) Adel clamps fuel pump holder 407000-87
(2) ¼-20 Male stud/Female rubber isolator 407000-27
(2) ¼-20x1/2 Flathead cap screw 407000-85
(2) ¼ Flat washer 402991
(2) ¼-20 Nylon locking nut 407000-40
(8) Mini Hose clamps 407000-75
(4) 5/16” F/I fuel line 24” long each 407000-64
(2) Isolator to assembly bracket 407000-68
(1) FMU Bracket 407000-47
(1) –8 female AN to –4 Male AN, fitting 407000-59
(1) Electrical nuts to fuel pump (packaged from
Vortec)
(2) M6x1.0 HHCS w/washers
1) Auxiliary Fuel Pump electrical assembly
(1) Fuel pump relay electrical assembly (Bosch relay
from Vortec, Stillen Assembly Dept. to wire)
(1) Fuel pump pressure switch 407000-49
(1) Blue 3M splice NEED P/N
(1) Hobb/boost switch bracket 407000-55
(2) 48” Blue silicone hose each 407000-16
(1) Power Steering oil cooler-Stillen (1999 models)
See P/N 407100
(3) Adel clamps SG-6 (1999 models) Part of BOM of
P/N 407100
(3) M6 x 1.0 x 10mm Flange bolt (1999 models) Part of
BOM of P/N 407100
(1) M6x1.0 Nylon locking nut (1999 models) Part of
BOM of P/N 407100
(1) Back strap 18” long (1999 models) Part of BOM of
P/N 407100
(1) Coolant bottle relocation bracket 407000-50
(1) 48” 5/16” hose, radiator overflow to coolant
bottle 405030-9
(2) Spring clamps, overflow radiator hose 407000-70
(1) Fuse box mounting brackets (teardrop) 407000-31
(1) Fuse box relocation mounting bracket 407000-30
(2) Flat head 10-32 x 5/8 451070-4
(2) 10-32 Nyloc nuts 407000-42
(2) 90° 3” OD tube w/Air temp sensor hole & crankcase
vent Assembled by__________________ Date
___________
(push in type and bolt in type air sensor) w/nipple
(407000-20)
(1) Modified oil drain back plate 407000-06
(1) Blower oil drain back hose-preformed 407000-32
(2) Hose clamps, # 10 407000-23
Hardware – Intake tubes Assembled
(1) Silicone hose, Black - 90°, supercharger to cross
over tube 407000-13
(1) Silicone Hose, Blue - MAS to 90° Ø 3.00 tube
407000-12
(1) Silicone hose, Blue - 90°tube to Throttle body
407000-12
(4) Hose clamp #48 Hard pipe/Mas/Throttle body
407000-19
(1) Blow Off Valve Assembly with adapter 407000-24,
-08
(4) Cable Ties, 11” Black 405030-6
(2) Aluminum spacers – Stand off to valve cover
407000-17
(1) M8x1.25x40mm Flange Head CS 407000-69
(1) M8x1.25 Prevailing Lock Nut 407000-86
(8) M6x1.0x55mm Hex bolt 407000-45
(8) M6 lock washer 318109
(2) M10x1.5x60mm Hex bolt 407000-33
(2) M10 flat washer 407000-34
(6) M6x1.0 Nyloc nuts 402993
(12) M6 Flat washers 318110
(6) M6x1.0x25mm Hex bolt 402990
(2) M6x1.0x40mm Hex bolt
(2) Hose Clamp #40 – Supercharger to 90°hose
407000-18
Vacuum line assembly Assembled
(3) Vacuum Tees, 3/16” 407000-28
(5) Cable Ties, 6” black 505053
(5) Vacuum lines, 3/16” ID 503215-6
(1) Air-bypass adapter 407000-78
(1)Cam sensor retainer 407000-84 Assembled
(1) C.A.R.B. Decal EO#D436-6
(1) 92 Octane Label WARNING
(1) Stillen SuperCharged Decal STISUPER
Old Aug 22, 2002 | 07:05 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Old Aug 22, 2002 | 07:51 AM
mtrai760's Avatar
'Trynna' is not a word
Ive been looking into this as well. It seems the hardest part is going to be making the mounting bracket... If the measurments are off at all, you are going to have premature belt failure and an unreliable system. You also have to come up with a good enough tensior system to not have premature belt failure or slipage. My plan right now is to reverse engineer the Steallin kit, and then make my own...
Old Aug 22, 2002 | 10:37 AM
dashingMax's Avatar
I totally agree with you on this. The BIGGEST thing would be to make that blower mounting bracket. Everything else can be easily fabricated. A good laser-based scan of the timing case would give you a 3-D image of the engine mounting area. Then a good CAD design tool should be able to design a mounting bracket...right? Since I am not a mechanical engineer, I wouldn't know how much more R&D this would require.
If we can figure out a quick way to design these mounting plates, then we could supercharge ANY car, as long as there is room to house the blower. In a couple of years, I would like to use my existing Stillen SC Kit & supercharge the Nissan Murano.
Old Aug 22, 2002 | 12:27 PM
mattC's Avatar
roots blower
Old Aug 22, 2002 | 01:50 PM
Bags's Avatar
VG Ridah's Biatch Hoe
vortech will seel you the blower.... and FMU if I can remember correctly..
The directions with parts list is online..just like sprint noted.
Old Aug 22, 2002 | 04:18 PM
JAY25's Avatar
If you come up with a mounting bracket!!!
you need to come up with a belt adjuster bracket and a oil return bracket as well!! it looks just like that timing case cover except it has a little tube to return the oil. Also the T to connect the oil sensor to send the oil up to the blower. Everything else could be easily fabricated!!!to include the crossover piping and so on etc..., bolts can be purchased at Napa by the box!!!they can get them , good luck with this project and put stealing out of business with their b/****!!!
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
TonyJr
Aug 20, 2015 12:14 AM
MikesChevelle
Aug 9, 2015 11:50 AM
laparka66
Aug 6, 2015 09:36 AM
