resurfacing rotors minimum thickness spec?
Hi. I need to have my rotors resurfaced again.
I have new brembos in that got warped, and I also have my old spare rotors out. I would rather resurface those so I don't have to do the labor twice. Those are also warped. Does anyone know what the minimum thickness is beyond which the rotor should not be turned? I want to make sure I am above spec before I have them turned. I basically have 2 sets of rotors cus these suckers get warped every few miles on me. Also, if someone can give me the nissan part number on front shims, that would be great, because the Nissan pads I bought don't come with shims.
Mostly I want the thickness spec though.
Re: resurfacing rotors minimum thickness spec?
[QUOTE]Originally posted by supertool
[ Does anyone know what the minimum thickness is beyond which the rotor should not be turned? I want to make sure I am above spec before I have them turned.
Front Runout 0.08mm 0.0031in Wear limit 20.0mm 0.787in
Rear Runout 0.15mm 0.0059in Wear limit 08.0mm 0.310in
Re: Thank you.
Does that mean that as long as the rotor is 20mm+ thick I am fine?
Thanks,
Thanks,
so I can't help you out there.
If you're going to use OEM spec rotors, you're much better off to buy them new than to have used ones resurfaced. I bought middle of the line rotors at NAPA for < $40 each. After 13K miles the stops are still smooth as glass.
Regardless of whether you use new or resurfaced rotors, make sure you follow the break in procedure: drive at 40 MPH for 1/4 mile, brake moderately to a near stop, repeat 12 times. Try not to come to a complete stop during the break in.
I just got new rotors recently. I don't want a third pair even at $40. A place around here charges $10/rotor to resurface them.
As far as all these break in procedures, that's the first I heard of them. I don't think about how I use the brake much. I do have ABS and I have automatic, so yes, I keep foot on brake when I stop. I personally torque them properly and correctly. I don't know if everyone who ever torqued my wheels rotating the tires or whatever does. After I turn these rotors again I will try breaking them in proper. Thanks for the info everyone.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
