My car is missing the self diagnostics screw
Old Sep 3, 2002 | 06:31 AM
infinitiblast's Avatar
I go to perform my self diagnostic's, and low and behold even though the sticker has never been removed I take it off. I notice that I cant get it to work, so this morning at work I have a friend show me how he test his. Oh wow no wonder it wont work, I dont have a freaking screw there. Anyone else have this problem. I have a 99 se-l does that make a difference.
Old Sep 3, 2002 | 06:45 AM
Jamsan's Avatar
ya the se-l is your problem....i forget where exactly its located, but its not down there in the normal spot....if you search, im sure you could find out more info about it
Old Sep 3, 2002 | 07:35 AM
thw625's Avatar
I have an SE-L also and had to run the diagnostic test recently. It is done the same way as on the other models. The screw on the ECU is labeled 'Idle Speed Adjustment' for some reason, but it will let you get the codes. The thing I got hung up on is that many posts say to use a flathead screwdriver, but on my car it was actually a very small phillips head screw. Once I figured that out it was easy. Hope this helps.
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
