OEM brake pad install experience,
Old Sep 7, 2002 | 03:04 AM
syc's Avatar
syc
well, I ordered my front OEM brake pad from courtesy nissan about 3 months ago and I installed them today.
I was trying to install the right side first. while I was installing the right side, I looked through the new pads and found out that there was only one pad that had the wear indicator. the other three did't have the indicator. further more, they didn't have the holes for the anti-rattle springs.
I was like WTF, they (nissan) put the wrong pads in the box. since I already spent some time on the car, I just installed all of them anyway so the left side brake doesn't have the wear indicator and no spring was installed because there was no hole. I tested drive the car, and feel normal. but I still got doubth, so I was thinking to come here to the .org and ask you guys about this tonight.
Later on, while I was trying to throw away the box, I found a very small piece of instruction sheet in the box. The instruction basically said the new brake pad kit is different from the original one from the car and it should contain only one pad with wear indicator. also, the pad with the wear indicator should be installed on the right side. So basically, I got lucky for installing the right side first with the wear indicator. I was even trying to go back to the old ones while the install.
One thing I learned from this is that: always look for the instruction sheet first before doing anything.
Old Sep 7, 2002 | 05:22 AM
karguy's Avatar
Re: OEM brake pad install experience,
[QUOTE]Originally posted by syc
[B]well, I ordered my front OEM brake pad from courtesy nissan about 3 months ago and I installed them today.
I would like to see wear indicators on all pads. You never know which wheel might have problems. You could be on bare metal on 1 of the other 3 wheels and not know it until you ruined a rotor. Shame on Nissan for being so cheap in their design!!!
Old Sep 7, 2002 | 01:04 PM
syc's Avatar
syc
guess I'll just check the pad using my eye whenever I do a tire rotation or something.
Old Sep 7, 2002 | 01:15 PM
karguy's Avatar
That is what I do. I personally rotate tires every 5k(hand torque to 80 ft lbs) and always check pad thickness plus look for problems, brake fluid leaks, etc...
Old Sep 8, 2002 | 08:49 PM
White96MaxSE's Avatar
Hand Torquing is smart. I have 192,000 miles on my Max and I have never turned my original rotors and I have no warpage.
I do hand torque, but I do 30 lb/ft around the car, then 60 lb/ft around the car, and finally the recommended spec for the max from my mechanic of 87 lb/ft for the final torque.
Tire Rack claims that a new set of tires should be rotated more frequently at first, around 3000 miles, then 3500 miles, the 4000 miles until you end up around 7500 miles at the end of the life of the tire. The reason for this is that the tire when it has more tread wears faster, and the more frequent rotation helps out with extending the life of the set of tires.
I do agree, though, that I was also disappointed when I last changed my OEM brake pads to also find a wear indicator on only one set of front pads (and found the explanation both at the dealer and in the little instruction sheet).
Just my two cents worth on the topic.
White96MaxSE
Old Sep 9, 2002 | 09:35 PM
Lonely Driver's Avatar
Nissan must not be selling enough rotors.
Old Oct 28, 2002 | 12:12 PM
sislen's Avatar
OEM brake pads
I recently replaced my OEM brake pads with Nissan OEM brakes. I was disappointed to find that the new brake pads did not include holes for the two spring retainers that existed on each of the front calipers.
I installed the calipers anyway and I havne't had any problems so far.
I also noticed the absence of the wear indicators.
Old Oct 30, 2002 | 07:20 AM
craigmax's Avatar
Any threads on changing pads?
Old Oct 30, 2002 | 08:00 AM
MrEous's Avatar
^ Jeff™
Re: Re: OEM brake pad install experience,
Wouldn't you be able to tell (by brake pedal feel) that there is metal to metal contact anyway?
Old Oct 30, 2002 | 10:33 AM
karguy's Avatar
Re: Re: Re: OEM brake pad install experience,
I don't think so, the first warning w/o wear sensors would be metal on metal noise. At that point you can order the rotor(s) you always wanted because you'll need them. I installed Raybestos Quiet stops 7 weeks ago, had holes in front pads for anti rattle springs and had a wear sensor(s) for each rotor (4). Also came with self adhesive shims and synthetic high temp grease. They are very quiet and veery little dusting!
Old Oct 30, 2002 | 11:40 AM
Dreizehn's Avatar
Re: Re: Re: Re: OEM brake pad install experience,
5th Gens don't have the anti-rattle springs on the front...
Setup is the same other than that...
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 17, 2016 04:54 AM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
