Should I use 110 octane fuel?
At my local drag strip you can get 110 octane race fuel.. Would this benefit my car in any way, or do you think it may actually hurt the performance. I just have simple bolt on mods
It will hurt performance and can possibly burn out O2 Sensors or your Cat.
High ocatane gas is used for very high compression cars running lots of power. Maximas are better off using octane in the 90s.
Re: Should I use 110 octane fuel?
There's no point unless you are running high boost. You don't need anything higher than 91-93. The higher the octane, the higher the rate of combustion..... higher octane prevents knocking in high compression engines.
Re: Re: Should I use 110 octane fuel?
Re: you can't use it
Originally posted by makattack
110 octane is leaded. Your car runs on un-leaded, it will clog and possibly seize your engine.
-RMB
Re: Re: you can't use it
Originally posted by rmb
If it is leaded it won't seize your engine but it will destroy your cats....
-RMB
-RMB
Originally posted by Corion
I thought high octane gas cleaned out your fuel system?
It's like running shoes. If you wear a size 10 but buy size 8, your performance suffers. You put on 10's and you can run great, but wearing 12's doesn't make you faster.
Re: Re: Re: Should I use 110 octane fuel?
Originally posted by sinewave
Actually, the higher the octane rating, the LOWER the rate of combustion.
higher ocatne= better for engine
110 octane is alot better for ur engine, ie u will get more power. especially if u have a super on there. 91 is like water compared to 110. but i dont recommend 110 for daily driving, its way too expensive
Ethyl Alcohol!!!!
Yup, use the good stuff BP/Amoco is using in their super expensive gas.
Buy Ethyl Alcohol and pour it down...that should give you the cheapest solution of making 150+ AKI.
It will be bad for engine if you run regular at this ridiculous level, but when used with caution, it can achieve supermotor effort (like beating Cobras).
Luck.
Luck.
Re: higher ocatne= better for engine
somebody didn't read the thread
Re: Ethyl Alcohol!!!!
Luck.
Luck.
Ammoco gas
Exxon gasWe dynoed bikes that used both gases exclusively. Exxon make more HP, burns better.
Re: Re: Ethyl Alcohol!!!!
Originally posted by maximised
Ammoco gas
Exxon gas
Ammoco gas
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
JoshG
51
Sep 21, 2015 10:41 PM
