New Pictures of my intake
Painted Red this time....
Snap-On Maxima
Sorry if not enough bandwidth....Angelfire sucks and I don't have money for other services...
Chris
Snap-On Maxima
Chris
Re: New Pictures of my intake
Snap-On Maxima
Chris
Snap-On Maxima
Chris
With the deal going on at Frankencar right now, you can start making them and make some $$$
Tifosi
Originally posted by mzmtg
I'm too lazy to search, do you have a link to all the parts you used and how you put them together?
I'm trying to figure out who's method/write-up I should use for the FAQ...
Just giving you a hard time...
I like!
I have the "$15 intake" in my car right now that was written up months ago (sorry, no link), but the 3" rubber plumbing coupling is kinda bulging out on the side closest to the firewall (on account of the angle it needs to make from the MAF to the OEM accordian tubing, so I think the airflow may not be as optimal inside there. It also creates a pathway with a larger internal volume & I think I may be losing a bit of low end, on account of the intake velocity not being high enough at low RPM's.
Also, I chose to do some clear silicone sealing on the inside of the accordian opening/coupling joint to smooth out the hard edge that the air would otherwise have to rush over/past at that joint. I think my work was well done and the joint is smoother now inside, but not nearly as smooth as a straight pipe (like yours) would be.
I'd definitely consider doing it your way if I could get a good writeup & parts list.
Great Pics - yer engine bay's lookin' mighty perdy!
Mahmuth
Sep 17, 2015 11:45 AM
doctorpullit
Sep 10, 2015 06:33 PM
lux97Max
Sep 4, 2015 05:42 PM
