Is there a way to take of the O2 sensor?
On the air Intake, right behine it, there is a little square bow that is presummable the "O2 sensor". There is a connector going into it from the engine. How do I take of the connectoR? All the things I liik up(book and web), it's allready off, seems a way of "popping" it off... there are 4 screws, but the connector seems to rest above them, so you can't get the screw driver into the screws.
Re: Is there a way to take of the O2 sensor?
the o2 sensor is on the exhaust just before the y meets the cat. and it screws in.
but if you want to take the connector off of the maf then take a small flat head screw driver and take the little metal clip that goes around it off and then you can pull the plug off.
oh yeah, be careful not to lose that clip awsm66 mentioned. nissan doesn't sell them individually. PITA.
Re: Re: Is there a way to take of the O2 sensor?
I did do searches, the search engine is just a little to foreign. I don't know if I can do "phrases", or for what AND works for, all sorts of other stuff. But when I look for stuff, I usually find 2 or 3 things, but never relevant enough to answer any questions for the small stuff. Expecially the stuff that most people assume you'd know...
Searching really hasn't been to helpful, unless it's for the very common problems, so that someone has had the same problem as me.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
