Need help on wheel and spacers!!
Old Sep 12, 2002 | 09:05 AM
Nightkidz's Avatar
My friend just order a set of new rims and tires:
235x45: 17x8 : offset is 45 and his driving a 96 maxima.
will this fit fine on his car or do he need a spacer (rear and front)??
If he does which brand do you recommand.
Old Sep 12, 2002 | 09:07 AM
voltman's Avatar
Fitment should be fine. Mount them and run them. If there is rubbing of suspension components, and 5mm spacers.
Old Sep 12, 2002 | 09:29 AM
Nightkidz's Avatar
thanks!!
can I have some more advice..
Old Sep 12, 2002 | 09:31 AM
voltman's Avatar
Re: thanks!!
Sure. Keep your money safe in Money Markets right now.
Old Sep 12, 2002 | 09:34 AM
Kevin Wong's Avatar
I have 235/45/17 on the Lexus GS400 17X8 wheels with a 50mm offset and there was a little rubbing when u-turning. It wasn't bad though. I wouldn't imagine you running into any problems.
Old Sep 12, 2002 | 10:41 AM
theblue's Avatar
yeah he got the wrong size but it should work...
Old Sep 12, 2002 | 01:35 PM
Nightkidz's Avatar
His worry about the wheel being too wide and the offset. Should he return the rims and exchange the a different one that will fit better.
Can you suggest the best combo.
Old Sep 12, 2002 | 02:36 PM
dashingMax's Avatar
The best combo would be 17x8 with 35mm offset running 235/45/17 tires...that is "best" IMHO.
Your setup should work just fine. I am not so sure about 45mm offset, especially, the 8" wheel width. If you had 7" wide rims, they should fit A-okay.
Like voltman suggested, try 'em on & if they rub, you WILL need some spacers, atleast 5mm.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
