Another convert from CAI to Hybrid
I cant believe how much high end power I had until I recently took out the lower CAI pipe and made a hybrid and the gains were VERY noticable
I thought I wasnt going to feel much but I cant believe how hard it now pulls at almost any speed except from a stop. What Im going to do now with my CAI hole in the fender is to get some flexible tubing and run an air scoop from the hole of the foglights and run it straight through the hole and face it to the filter for some extra air
I didnt really feel any low end lag but thats maybe because I never really floored the car from a stop much so I couldnt really tell the difference from hybrid and CAI from a stop. However, I felt a very huge gain when the car is moving though. I did a few runs tonight.I Took the car to the same road when it had CAI and not only hybrid pushed me back in the seat harder but you can watch the tach and speedometer rise much higher and faster than the CAI did
Originally posted by BigDogJonx
My opinion, I think it is in your head.
Dixit
Dixit
Re: Another convert from CAI to Hybrid
BTW: Your Homepage link is broke!! I'd like to see your intake..
Did you notice it right away?
I wonder if it will feel the same after a week of driving; I found that after any changes the ECU took a little bit to learn the changes.
If you continue to claim the same increases in a week, maybe hybrid is the way to go for me too!
also, after a couple of weeks now, there's a whistling sound starting to become more frequent too.. Anyone else hearing that in thiers?
Maybe I'm just lost but how can I make my POP intake into hybrid. Is it just an extra tube that conects to the cone?
I did a big write up on by conversion from CAI to Hybrid. Check it out:
http://forums.maxima.org/showthread....=CAI+to+hybrid
Since I am 5spd I felt NO lag in low end power, and DEFINATALLY felt it pull harder after 4,000RPMs. I agree with Dave B. that is tried and true.
i still dont understand why people are debating this topic.
like a year and half after the first initial posts.
aiya!
PR upper piece, JWT or stillen pop charger will produce better hp overall.
i said it before. ill say it again.
CAI is great for low end power. but it sucks on the top end dueto the resonance of air flow.
to combat the die off, you want the air to flow faster at higher rpms, the only way is to have the intake closer to the TB.
adding a popcharger to the end of a full PR CAI will help a little bit, but not as much as this "hybrid" intake system.
every intake system has its draw backs. just pick one of the lesser evils.
--cheston.
aiya!
--cheston.
Re: Re: Another convert from CAI to Hybrid
aiya!
--cheston.
aiya!
--cheston.
Five speed 0-60 ( )
Five speed 1/4 mile ( )
Auto 0-60 ( )
Auto 1/4 mile ( )
Any information would be helpfull, how is the supercharger rebuild coming?
oddly enough, when i put in my custom (had a muffler shop cut a pipe for me) hybrid the other night, i reset my ecu and went for a drive... it could tell an immediate difference. but as i drove the next day, it didn't feel the same. granted the air temp was about 60 that night and about 85 the next day. but even the following night it didn't feel as strong... so i reset my ecu again.. and it felt like it did the first night.. i was spinning 2nd and i chirpted 3rd twice. is there something to this or am i just imagining the diff. after i reset my ecu?
Dixit
Dixit
Brian's CAI had slight edge in low-end power, but after that, it was all Hybrid..CAI fell short of Hybrid intake's top-end..
to read about this article, go to www.maximadriver.com and find it under the tech article section. http://vbxmaxima.8m.com/caivssi.html
after crashing my old max, i bought a newer one. i have my place racing CAI getting ready to be shipped. do you guys think i should just get a hybrid intake, or get a jwt popcharger?? my top is ok, i actually want my low end better but i dont want to loose my top end, i love it
should i replace an order??? where can i get a hybrid if so. thanks
Originally posted by irvine78
Cheston and BrianV did a dyno test of Cheston's hybrid and Brian's PR Intake. both with Stillen cone filter attached to it.
Re: Re: Re: Another convert from CAI to Hybrid
Originally posted by Street Reeper
Do you speak from exprience, if I'm not mistaken you used to have the place racing intake? Unless to smooth out the incoming air I don't see how a midpipe is going to be an advantage over a pop charger, since they both get incoming air from the engine bay. If this piping is good why would a PR CAI not be better, it's piping doesn't seem that much longer, but it draws air from outside the engine. Has the length of the midpipe been R & D, is this the optimal length for an intake pipe. Was it just an accident that those who engineered the CAI just happened to make the midpipe the perfect length even though this was not in their design plans. What would your opinion be for an optimal intake for
Five speed 0-60 ( )
Auto 0-60 ( )
Auto 1/4 mile ( )
Five speed 0-60 ( )
Auto 0-60 ( )
Auto 1/4 mile ( )
Originally posted by 97MaxGurl
I'm switching too
http://forums.maxima.org/showthread....hreadid=153098
I'm switching too
Next time you go to the track, please post times with the hybrid and hopefully the temperature is the same as the last time you went
I can 'feel' the positive difference already. I will post track numbers next month. Hopefully the temperature drops
Ange
So just out of curiosity, how much of a difference is there going to be if I just put my CAI filter on the end of the mid-section as opposed to a JWT style filter?
Kinda a n00b question, but I'm curious because I'd prefer not to have to go out and get another cone intake, and my old JWT is MIA.
I would think nothing at all, but everyone seems to be doing it that way.
...plus you already have all the parts needed.
Originally posted by UMD_MaxSE
what you have described is exactly a hybrid setup.... Give it a try, you may like it
Soon as Schucks auto parts opens up (need K&N cleaner), I'll give it a shot and report back.
Hopefully I'll see some gains. Free mods are nice when you live in Seattle and have a fiance the lives in Tucson. Not exactly cheap to fly down every month...
Hmmm, well, I tested it this morning when it was fairly cool out, and now it's maybe 10 degrees warmer. I decided to break out the digital video camera, and actually compare numbers that way, along with my butt dyno.
I'm *hoping* the temp outside made a big difference, because the car didn't feel any quicker, and judging from the times on my vids, the hybrid was about almost 1.5 seconds slower 0-60, and about a second slower from 30-60 and 50-90. I reset the ECU when I did the change, so I don't think that's it. So, would the temp make that kind of difference, does the ECU just need more time to adjust, or is my car just different from the others who've had good experiences with it? Any ideas? I'm not really looking forward to putting the CAI back on...
I think I did it right...I had a slight fitment issue due to the nitrous solendoids, but that was it. Hmmm...
setup looks ok... give it some time... low end is going to feel a little different from the CAI....
carid
Sep 9, 2015 05:06 AM
