Does anybody know what this code goes to?
Old Sep 20, 2002 | 12:43 PM
JAIMECBR900's Avatar
I got the dreaded CEL yesterday. Pulled the code, 0806. According to the decoder, it goes to the EVAP canister control valve/solenoid.
Does anybody know what in the heck that is? Please advise.
Old Sep 20, 2002 | 12:45 PM
Jeff92se's Avatar
I'm needing a caw
http://forums.maxima.org/search.php?...der=descending
Old Sep 21, 2002 | 09:22 AM
Thank you very much I will check it out.
Old Sep 24, 2002 | 08:23 AM
I read the search link, and I have the basic idea.
One more question though, where is the solenoid located. Dave mentioned briefly that is was "on top of the engine", but where? What does it look like? Does anyone have any pics or links for me to see what it looks like before I start taking things off and spraying them down with WD-40? Please advice, my CEL is back on again and I want to take care of this problem right away. Thanks in advance for your help.
Old Sep 24, 2002 | 11:14 AM
Swafford98's Avatar
whats up Jaime?
I threw the same code as well. It is usually associated with the knock sensor i believe. The EVAP canister is located behind the drivers side rear wheel and it is a Black box the is about 12x6". It has a bunch of hoses coming out of it as well.
MY question is that i threw the EVAP sensor and where is that located? There is some type of open/close valve that is attached to the box and that can be removed.
Let me know if you find out anything... becasue i need to replace mine. I have heard that they run around $80.00,but not for certain.
Old Sep 24, 2002 | 11:29 AM
Bags's Avatar
VG Ridah's Biatch Hoe
If you come out tonight I will bring my FSM for you
Old Sep 24, 2002 | 11:58 AM
What's an FSM?
Old Sep 24, 2002 | 12:17 PM
Bags's Avatar
What's an FSM?
Factory Service Manual
Old Sep 24, 2002 | 12:20 PM
cool, i think i am going to be able to make it...just tell me when and where. I may be a little late since my daughter doesn't get out of cheerleading practice until 7:30-7:45. Let me know.
Old Sep 25, 2002 | 11:10 AM
Swafford98's Avatar
i went to town center Nissan and they said my sensor is only $42.00. I am getting it tomorrow after i get paid
while i am there i will see how much your solenoid is. I have heard that they have the cheapest prices on parts right now.
Old Sep 25, 2002 | 11:16 AM
Shoooter_j's Avatar
Guys I had the same code dealing with the EVAP Solenoid and Purge valve (0807). Check if there is anything blocking the smallest hose/tube from the midpipe. Mine was blocked with excess metal/material (from the inside of the midpipe) and I had to remove it. So far, no probs and no ECU comin on again.
Old Sep 26, 2002 | 08:37 AM
Swafford98's Avatar
the snallest pipe coming off of the EVAP box?? The black box located at the rear of the car.
Old Sep 26, 2002 | 08:50 AM
I have no clue where the solenoid is to start tracing. I know where the canister is, but not the solenoid. What hoses are you referring to?
Old Sep 26, 2002 | 10:15 AM
matt calder's Avatar
The solenoid is the black thing pluged into the evap canister right behind the drivers side wheel. It has 2 hoses (i think) that connect to it.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
