0409 MIL code
0409 MIL code
Last night while driving the SES light randomly came on and i pulled the code 0409 when i got home. i checked on here and it says the code is for a malfunctioning oxygen sensor. after i reset the light i went and drove and the car as performing a whooooole lot better and when floored it would shift/acclerate a lot quicker. after i turned the car off again and started it back up, it was back to being its sluggish self. so im wondering if its the o2 sensor thats causing this or if it could maybe be a bad knock sensor or something like that which was reset when i cleared the MIL.... thanks
-doug
-doug
Re: 0409 MIL code
-doug
-doug
P.S. - You can do this yourself pretty easily, as I did. Most dealers charge around $180-$220 to replace it for you.
-Chad
Re: 0409 MIL code
-doug
-doug
If you're not getting the knock sensor code when you read them, consider yourself lucky, as that definitely isn't the problem in your case then.
so did you replace both the o2 and knock sensors, or just the knock sensor?
-Chad
hey everyone, im so proud of myself because i replaced the o2 sensor that was bad today, even though it took 1.5 hours. well after i replaced it i cleared the ecu AND disconnected the battery to make sure all the codes were out. the power delivery seems to be a little smoother but my acceleration is still below what it should be and the time to kick down at WOT is still slow. what else could be causing the car to run slow? i know the knock sensor could be causing this but it isnt sending out a code....any ideas?
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
