Is clutch smell an indicator of something bad?
Old Sep 26, 2002 | 10:47 PM
Blaxxxima's Avatar
!OG SNES OG!
I find that after i gun my engine a bit to get it started moving (ACT clutch), it smells, especially if I'm going upwards of 3K RPM. Is this a result of the clutch being pushed, but the car not moving, and it is causing a burning effect (hence the smell)?
I have about 3K on my new ACT, and I'm sure I'm not abusing it (too much). Just want to know if I'm harming my car in any way, or too much.
Thanks in advance!
Mike
Old Sep 27, 2002 | 03:58 PM
poorcollegeboy's Avatar
Re: Is clutch smell an indicator of something bad?
Thanks in advance!
Mike
that bad smell is your clutch burning. any clutch burns - performance or not. burning the clutch is BAD. if you are going to rev that high (above 3k), you shouldn't feather the clutch.... drop it. (dropping clutch will wear your mounts. you can't win )
Old Sep 27, 2002 | 04:04 PM
see5's Avatar
Quick, adjust your clutch or you will smoke it!
Old Sep 27, 2002 | 04:36 PM
Ghost face Max's Avatar
I was getting that same smell for a little while after the install of my Act clutch. But smell just went away and I took back to my mechanic, he test drove my car and check the clutch it was fine he couldn't find anything wrong at all...
Old Sep 27, 2002 | 04:41 PM
Blaxxxima's Avatar
!OG SNES OG!
What would they adjust?
The spring tension on the clutch? I'm a mechanical noob, so if you could clarify that would be greatly appreciated
Thanks!
Mike
Old Sep 27, 2002 | 05:00 PM
see5's Avatar
Re: What would they adjust?
Thanks!
Mike
You can adjust the engagement point from the point where the rod goes thru the firewall. Lie on your back and look up to the adjuster.
Old Sep 27, 2002 | 05:22 PM
mtrai760's Avatar
'Trynna' is not a word
Re: Re: What would they adjust?
wouldn't his clutch slip if that was the case?
Mar 12, 2020 12:06 AM
Smackasmith
Feb 1, 2016 12:40 AM
RWCreative
Sep 21, 2015 11:01 AM
carid
Sep 17, 2015 05:00 AM
dcam0326
Sep 7, 2015 07:26 AM
