Gauges ?
Nice work man!
Originally posted by 97' SEan
If you just like Blue like me you can keep the white and enjoy the blue at night.
Sean
Sean
Mike
As many times as I've had the dash apart I can do it in less than 5 minutes. Just got in my new 194 bulbs from www.superbrightleds.com Paid $1.59 each x 5
One thing though, if you want your needles to glow blue you need to remove them and scrape the orange paint off carefully with a razor blade. Be very careful to keep your gauges in alignment, took me a few tries. If you need any help let me know. Also check out my other blue mods on my homepage. Sean
#1 what bulb is behind the gauges and is it easy to install
#2 Where can i buy the windows switch bulb and is it easy to install it myself
#3 What bulb is the Acc light, Hazard Light, Keyring, Ashtray and security.
Now i probably need u to help me install like u did. And where can i buy the bulbs for each
Originally posted by elgatomax
Dude your blue light project is tight. Im doing the same thing. I want u to explain me some things
#1 WLED-B Blue LED bulb You need 5 but get 7 if you want to do doors.
http://www.superbrightleds.com/cgi-b...gi?product=CAR
#2 All of my blue lights are Leds, you have several choices, you can go to your local radio shack and get part #276-311 for $2.99 ea kinda of a deep blue almost purple, that's how I started out. They also have brighter led's for $3.99, those are what I used for the Defroster, Keyring, Security, Speakers, and under seat lights. Finally after blowing $50 at RS I got smart and ordered 20 leds for $1.09 ea off the above site.
#3a Acc light = 4 leds here is a link on how to do them although I did them differently: http://www.z3d.com/maxima/blueclimate.html
I chose to solder them directly into the circuit board with a resistor on each led. Also be aware that the two leds in the front buttons are quite difficult to replace with standard 5mm leds, I used a dremel drill to shape them to size, otherwise the button sticks. If I had it to do over again I would use these: http://www.eled.com/product.asp?cata..._id=E1777MBSGW
The led on the left needs a resistor and the one on the right I did not use one. For some reason the button on the right would be very dim with a resistor and nice and bright without, I tested it and it hasn't burned out yet so it should be ok. For all the leds I have been using 330ohm resistors.
#3b Hazard light = lots of patience, also a small led with resistor, the switch itself needs a little modifying, practice taking it apart and putting it back together, took me over an hour
#3c Keyring = challenging, I used a $3.99 led from RS and connected the negative side to wire and grounded it, the positive side I connected to the 12v on the bulb socket.
#3d Ashtray = one of the easier ones, took out old bulb, soldered in led from rs with resistor
#3e Security = actually used an led from a photon light, very bright, just replaced the red led with the blue pretty simple, resistor already built in the rubber holder.
Hopefully you haven't fallen asleep from the excrutiatingly long post. Many of the switches you need to be creative to mount the led, there is very limited space in most of them. I can send you pictures of each of them and how I mounted them, hope you have a good soldering iron, cold fan, and a burning desire to see blue!
Sean
Thx, Put way too many hours into it though.
Sean
Sean
for the gauges light where can i buy them
From here ==>>>> #1 WLED-B Blue LED bulb You need 5 but get 7 if you want to do doors.
http://www.superbrightleds.com/cgi-...cgi?product=CAR
site didnt work
site didnt work
under this line Single LED Wedge Base Lamps
click buy online on the left or see specs for info
Sean
http://www.superbrightleds.com/1157.htm
Sean
Sean
so i cant buy this at a store only online
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
