Tire situation, what would you do?
Old Oct 15, 2002 | 01:06 PM
MaxSpeedSE's Avatar
Ok guys i took my car to discount tires today to get my tires checked because my car was bouncing and the ride was not smooth, they looked at the front two tires and there were huge chunks missing from them. They called them braking spots. Ok so they put them in the back, so I don't feel them, and the ride is smoother but the thing is when I rotate my tires wont I have a problem? If I always keep them in the back? Maybe if I take them off the rim and flip them every time I have them rotated? What would you guys recommend, just keep them in the back, or say **** it and spend $300 for two new tires?
-Chri§
Old Oct 15, 2002 | 01:09 PM
SuDZ's Avatar
When you do rotatethem then yes they will end up back up front. Maybe if you dont want to buythem all at once buy them seperate and havethem put on when you do the rotation.
SuDZ
Old Oct 15, 2002 | 01:10 PM
Canuck's Avatar
Re: Tire situation, what would you do?
-Chri§
You can get rid of braking wear by doing a burnout if they are not really bad. Of course the tires will loose some tread from this and not last as long but they will perform and ride better provided you don't burn them till they are bald.
Old Oct 15, 2002 | 01:13 PM
MaxSpeedSE's Avatar
Im only having a problem with 2 of the tires... i figure id keep them on the back...and just rotate them , staying on the back ...
Old Oct 15, 2002 | 01:15 PM
MaxSpeedSE's Avatar
Re: Re: Tire situation, what would you do?
yeah there REALLY bad... you can run your hand on them and feel them go in
Old Oct 15, 2002 | 01:23 PM
Str8ridin's Avatar
Re: Re: Re: Tire situation, what would you do?
then, put 'em in the front, pull the handbrake up and light those bad boys up after you rotate again.
Old Oct 15, 2002 | 08:33 PM
MaximaMoJo's Avatar
When I purchased my car the dealer told me that one of the front tires had a flat spot(dealer discounted the purchase price). So I called my local michelin dealer and they put two new tires on for $80. I will keep these on the stock rims. I would try contacting an authorized dealer for your tire manufacturer.
Old Oct 15, 2002 | 08:37 PM
Canuck's Avatar
Re: Re: Re: Re: Tire situation, what would you do?
Its actually a reasonable excuse to do a burnout
Old Oct 15, 2002 | 09:05 PM
MaxSpeedSE's Avatar
You have to understand, i cant go to the dealer, or just pick up two tires for 80 bucks, i need peformance tires becuase i have aftermarket rims
2 for me would be 300 bucks!
Old Oct 16, 2002 | 05:32 AM
T-bone's Avatar
I'm curious..how does doing a burnout impove the situation
Old Oct 16, 2002 | 07:17 AM
Str8ridin's Avatar
burnouts take a layer of rubber off the tire and smooth out any flatspots. basically, all the tread will now be even with the lowest spot on the tire.
Old Oct 16, 2002 | 08:05 AM
Canuck's Avatar
Exactly
Old Oct 16, 2002 | 08:18 PM
MaximaMoJo's Avatar
I'm was talking about contacting the manufacturer of your tires. Is there a local authorized dealer for your brand of tire in your area. It is worth the 5 minutes to make a call. If the manufacturer of the tire believes it could be a defect in the tire they could replace your tire for free or at a discount. Worth a try? Just trying to help.
Old Oct 16, 2002 | 08:50 PM
ericdwong's Avatar
Do burnouts on them and it will make them rounder.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
homewrecker
Sep 24, 2015 07:01 PM
